7.3 ugrades? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 66 (permalink) Old 06-27-2013, 01:56 AM Thread Starter
7.3 ugrades?
I am looking at a couple kits to add to my truck and need reviews on them. Looking into coolant filtration system, hot start coolant heater, oil filtration system, hot start oil heater and fuel return system. Wanting to get as much life out of my truck as possible. Let me know any pros and cons with any of these mods. Or if you know of something better let me know.
powerstrokecowgirl is offline
post #2 of 66 (permalink) Old 06-27-2013, 02:34 PM
SledDogg's Avatar
Re: 7.3 ugrades?
Uh...ok.
* First is a solid air flow and 4" turbo back exhaust.
*Run synthic oil (5w40 is what many run) in winter. Summer would be bettter but def helps in winter.
*solid oil filter I use Motorcraft or Purolator PureOne and running 7-20k oil tests good(filter changed every 7k).
*I have seen a 1 mpg increase in my last two trucks with Amsoil in diffs, transfer case, power steering, and transmission.
* Coolant filtration will help.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #3 of 66 (permalink) Old 06-27-2013, 03:06 PM Thread Starter
Re: 7.3 ugrades?
I have k&n air filter and 5" exhaust. I run synthetic oil and k&n filter. I change mine every 5k. And I have am soil in my differentials sand transfer case. So was wondering what would help the longetivity of my truck.
post #4 of 66 (permalink) Old 06-27-2013, 03:13 PM
fpOwerstRokeD's Avatar
Re: 7.3 ugrades?
take that k&n off and throw it in the trash it will dust your turbo
03 F-250 lariat 7.3,ZF6,gauges,6637,banks exhaust brake(came with the truck). FASS fuel system.
fpOwerstRokeD is offline
post #5 of 66 (permalink) Old 06-27-2013, 04:02 PM
juvenile9's Avatar
Re: 7.3 ugrades?
99.5 F-350 4x4, 6637 Air Intake, Stage 1 Single Shots, 5 Inch Exhaust, Wicked Wheel, 4" Lift, EBPV Delete, Gauges, Tru-Cool Tranny Cooler, TS 6 Position Chip with Gearhead Custom Tunes, International Bellowed Pipes, and Built Auto Tranny
juvenile9 is offline
post #6 of 66 (permalink) Old 06-27-2013, 05:06 PM
the stryker god
Re: 7.3 ugrades?
Get a ford ais intake, frx, hutch mod, 6.0 tranny cooler if you have an auto, good oil and change it regularly.
bruce51d is offline
post #7 of 66 (permalink) Old 06-27-2013, 05:16 PM
Village Idiot
southmike's Avatar
Re: 7.3 ugrades?
If I had the budget I would do the dieselsite coolant filter kit.
an oil bypass filter system system..i like fs2500, but I hear oil guard is good as well.
not sure about the hot starts system..where do you live ..ie Alaska?
there is a built in heater that takes care of most needs..
if anything I would look at an oil prelube kit such as Engine Pre Lube System Insta-Lube Kit Installation
southmike is offline
post #8 of 66 (permalink) Old 06-27-2013, 05:29 PM
the stryker god
Re: 7.3 ugrades?
Bypass isn't as effective in our engines due to how bad our oil shears. Waste of money IMO, the hot start things are a waste IMO as well
bruce51d is offline
post #9 of 66 (permalink) Old 06-27-2013, 06:32 PM
Bobs 7.3
Bobs 7.3's Avatar
Re: 7.3 ugrades?
First thing is ditch that k&n quickly youll thank yourself and the stock airbox ditch with the k&n and get a good aftermarket set up. The stock air boxes are junk too and dont seal properly.
Bobs 7.3 is offline
post #10 of 66 (permalink) Old 06-27-2013, 06:41 PM
Bobs 7.3
Bobs 7.3's Avatar
Re: 7.3 ugrades?
I run a 6637 kit on mine and works great and it was $80.00 and got rid of the stock airbox and filter all together.
Bobs 7.3 is offline
