lowering the compression ratio? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 01-20-2009, 12:26 PM Thread Starter
casper7.3's Avatar
what are the advantages, benifits of doing this? at what point would one consider this? allowing more boost i guess would be one reason. just curious..
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
casper7.3 is offline
post #2 of 39 (permalink) Old 01-20-2009, 12:30 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: lowering the compression ratio?
Lowering the compression ratio mechanically reduces cylinder pressure, which is easier on the rotating assembly. It allows the engine to easier handle higher boost and fuel volume, there is more area in the cylinder. The correct way to do it is machining out the piston's bowl, like this:
Stock
PowerstrokeJunkie is offline
post #3 of 39 (permalink) Old 01-20-2009, 10:38 PM
Got Bost???
NyCowboy87's Avatar
Another way to do it is like this.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #4 of 39 (permalink) Old 01-20-2009, 10:41 PM
Who does this? And how much does it cost? Do you just use Mahles for this? Thanks.
bigjake0524 is offline
post #5 of 39 (permalink) Old 01-20-2009, 10:45 PM
Got Bost???
NyCowboy87's Avatar
I just used the stock pistons as they were fine and had my uncle cut them for me. Most everyone uses Mahles (which is the oem manufacture).
Tow Mule
post #6 of 39 (permalink) Old 01-20-2009, 10:57 PM
HRT Performance
HotRodTractor's Avatar
Another vote for machining the bowls!
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #7 of 39 (permalink) Old 01-20-2009, 11:25 PM
fueled by Colecovision
golfer's Avatar
Garage
golfer is offline
post #8 of 39 (permalink) Old 01-20-2009, 11:43 PM
Layson's Avatar
How much does this effect starting in colder climates?
Layson is offline
post #9 of 39 (permalink) Old 01-20-2009, 11:58 PM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
That depends on how much compression you take out of it.
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #10 of 39 (permalink) Old 01-21-2009, 12:14 AM
Mine is 15:1, and with glowplugs, it starts up fine outside, but will chug the white smoke, for a very long time, and will blow white/blue for a minute or two going down the road under light throttle. I try to keep it in the heated garage and it likes it..
But if you don't wait for the glowplugs..
Stock
