6 Leaker IC install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-20-2009, 03:00 AM Thread Starter
SD01WD's Avatar
6 Leaker IC install
Can anyone who has installed a 6 leaker IC in a 7.3 say 2001 please tell
me what all is required? Are there any mods? Please help me so I don't
get into this and find a major hold up.
Thanks
2001 SD 2 wheel drive
DP tuned by Scott @ TNT of CC
ITP Regulated Return/ in tank & prepump mods: When Only the BEST will do!
Tank has been harpooned
Gages: Boost and Pressure
on the post & 4" S/S turbo Back by Aljay.
Rancho's all around
SD01WD is offline
post #2 of 13 (permalink) Old 01-20-2009, 03:11 AM
Proud PSN Sponsor
Deputydog's Avatar
Re: 6 Leaker IC install
Here is a little install article..
http://www.powerstrokedatabase.com/read.php?id=201
You're gonna need new boots.
One of these
http://www.dieselpowerproducts.com/s...php?id=97&=SID
And one of these
http://www.dieselpowerproducts.com/s...php?id=96&=SID
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #3 of 13 (permalink) Old 01-20-2009, 02:20 PM
Village Idiot
southmike's Avatar
or dieselsite.com 6.0 install kit
http://www.dieselsite.com/index.asp?...ROD&ProdID=861
which won't expand to oil exposure.
bob's (Riley) boots are great but not cheap, but not as expensive as "Bob's Boots"
southmike is offline
post #4 of 13 (permalink) Old 01-20-2009, 03:12 PM
fbilly420's Avatar
Dont forget you will need to tweek the trans cooler mounts.(If your still running the stock trans cooler) If I coukld do it again I would install the 6oh trans cooler at the same time.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #5 of 13 (permalink) Old 01-20-2009, 05:14 PM Thread Starter
SD01WD's Avatar
Gosh guys this is great and I thank you for the quick replys. I will check out
the hose size and order one before I get into the project.
Thank you all for the help.
Bill D.
Rancho's all around
SD01WD is offline
post #6 of 13 (permalink) Old 01-20-2009, 07:40 PM
treyloco's Avatar
Also make sure you do not kink any of your cooler lines. Unbolt your cooler and leave it unbolted until you get the new IC in place and you should be able to bolt back up in the same holes. those two cooler lines seem to be the only things that really get in the way.
'03 7.3 lariat crew cab dually FX4
AFE Stage 2
DI 6 position
warn premium hub locks
4" mbrp straight piped exhaust
custom built trans w/ triple disc converter
'07 Front End w/ 6000k HID
AIH delete & CCV Mod
Just over 100k miles
"Powerstroke Performance Headquarters!"
treyloco is offline
post #7 of 13 (permalink) Old 01-20-2009, 11:54 PM
Village Idiot
southmike's Avatar
re: tranny lines
only on a few trucks but seems like they were o1's
also joe aka ..cspid put one on his truck i believe I think he had to adjust his lines a lil.
good idea about the tranny cooler, if you cant get a 6.0 a v10 is still a great improvement and 1/3 the price.
post #8 of 13 (permalink) Old 01-21-2009, 12:31 AM
fbilly420's Avatar
I just tweeked my cooler lines and also the mounting brackets to get mine to fit.
workin on body
post #9 of 13 (permalink) Old 01-21-2009, 12:51 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Originally Posted by southmike View Post
re: tranny lines
I just made a bracket that lowered both the tranny and the PS coolers...
I also just extened the passanger side IC tube rather then use a new boot.
Joe
CSIPSD is offline
post #10 of 13 (permalink) Old 01-21-2009, 03:33 AM Thread Starter
SD01WD's Avatar
I want to thank you all, I appreciate the help. I measured the tubes.
passenger tube 3" Passenger IC tube 3 1/4" plastic.
Drivers tube kept comming up 3 1/8" with caliper? But the I/C tube 3" plastic.
I will order the correct connecting hoses and modify the Trans cooler bracket
if I can not find a 6.0 trans cooler.
Thanks for all the help. I don't intend to step up the power as the DP is for towing my trailer for my 10 sec street stang.
Rancho's all around
SD01WD is offline
