Fixing to install Gauges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 06-25-2013, 02:27 AM Thread Starter
hunter scar's Avatar
Hey guys my issapro guages will be here Wednesday. I ordered the Ev2 boost and pyro. I know it goes pre turbo is it easier to put the probe in the manifold or the up pipe? Also would that make any difference on the pyro reading? Thanks Hunter
1997 f250 ex cab short bed 4x4, 5 speed, tymar intake, 3inch mbrp downpipe to 5inch straight pipe, 2inch rough country front add a leafs. more to come. Totaled
2002 f250 ex cab short bed 4x4, 6 speed, tymar intake, 4inch downpipe to 5inch strightpipe, leveling kit ,issapro ev2 boost and pyro, PHP Hydra
hunter scar is offline
post #2 of 16 (permalink) Old 06-25-2013, 02:30 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Fixing to install Gauges
Drill and tap the manifold... Easy and done. No differance in readings.
Joe
CSIPSD is offline
post #3 of 16 (permalink) Old 06-25-2013, 02:42 AM Thread Starter
Thanks for the info. This is my first pyro install and just worried about messing something up. Just out of curiosity what kind of metal is the up pipe made out of?
post #4 of 16 (permalink) Old 06-25-2013, 02:47 AM
CSIPSD's Avatar
Up pipe is just stainless.
Mainfold is cast iron.
Drill, tap and install.
Do not worry about shavings, do not worry about grease on the bit, worry about all the shavings falling in your face and wear safety glasses.
Joe
CSIPSD is offline
post #5 of 16 (permalink) Old 06-25-2013, 02:56 AM Thread Starter
Thanks for the info! I would feel better putting it in the up pipe in case something went wrong i could weld the hole shut. And redo it would that work ok?
post #6 of 16 (permalink) Old 06-25-2013, 03:06 AM
CSIPSD's Avatar
Put it in the mainfold... Drill tap and install.
Have you ever tapped anything?
Put it in your up pipe, weld it up in a few months or put it in the mainfold and be done.
Its your choice, do it once, or twice.
Joe
CSIPSD is offline
post #7 of 16 (permalink) Old 06-25-2013, 03:23 AM Thread Starter
What do you mean twice? What i meant was if their was a chance i messed up drilling or tapping the hole in the up pipe i could weld it closed, and could drill a new hole and tap it. No my buddy is in college to be a machinist i was gonna get him or my grandpaw to help.
post #8 of 16 (permalink) Old 06-25-2013, 03:28 AM
CSIPSD's Avatar
Drill and tapping the up pipe is a dumb idea, its super thin... 4 threads vs 20 threads...
Joe
CSIPSD is offline
post #9 of 16 (permalink) Old 06-25-2013, 03:30 AM
'94IDITurbo7.3's Avatar
drilling and tapping the exhaust manifold is about the easiest thing i have ever drilled and tapped. the cast iron is super soft.
I think what Joe might be getting at is that if you put it in your up-pipe then the bung could blow out or something along those lines do to the thin tubing.
1994 F-250, 7.3L IDI Factory Turbo, E4OD, 4.10 LS, XLT, SCLB, 2WD
'94IDITurbo7.3 is offline
post #10 of 16 (permalink) Old 06-25-2013, 03:35 AM Thread Starter
Oh ok i understand thank for the info guys! I have also heard not to run the tap all they way throw the hole something about the n.p.t threads being tapered?
