Hypermax turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 06-25-2013, 12:25 AM Thread Starter
Hypermax turbo
I bought the truck with it already installed. Its a 2002 f350. The trouble Im having it that it doesn't produce boost until 1800 rpms, and in stock mode it barely gets over 10psi. I was wondering if anyone knows are a way to get it to boost up sooner and/or produce more boost without having to turn up the power level
jaydirt is offline
post #2 of 16 (permalink) Old 06-25-2013, 02:30 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Hypermax turbo
What other mods do you have?
Smoke issues?
EGT issues?
Joe
CSIPSD is offline
post #3 of 16 (permalink) Old 06-25-2013, 02:41 AM Thread Starter
Re: Hypermax turbo
Nah, no issues. I just assumed if you put on an aftermarket turbo that it will spool up sooner in the rpms and give you more boost. Like I said, on the stock setting it maxes out at 10-12psi. Even if I turn up the power it still wont boost up until 1800rpms
jaydirt is offline
post #4 of 16 (permalink) Old 06-25-2013, 02:48 AM
CSIPSD's Avatar
Re: Hypermax turbo
I would check for boost leaks. Stock HP settings and a standard H2e should see about 15-17 WOT.
Joe
CSIPSD is offline
post #5 of 16 (permalink) Old 06-25-2013, 02:58 AM Thread Starter
Re: Hypermax turbo
wouldn't that be something you'd hear if not even notice?
jaydirt is offline
post #6 of 16 (permalink) Old 06-25-2013, 03:07 AM
CSIPSD's Avatar
Re: Hypermax turbo
Nope...
Take a 3" PVC cap, drill a hole in it and hook a compressor to it. Install on the intake, pressurize to about 20 psi and spray soapy water on all the boots.
Fix boost leaks and report back.
Joe
CSIPSD is offline
post #7 of 16 (permalink) Old 06-25-2013, 04:01 AM
geared_low550's Avatar
Send a message via AIM to geared_low550
Re: Hypermax turbo
Originally Posted by CSIPSD View Post
Nope...
Thanks. I been tryin to rig up a way to pressurize it and check the same thing on mine that's stock all the way. It just seems slow to light. And T 297k miles I don't know if the boots are original. They are all black boots. With writing on them identifying where they go.
08 250= sold
2005 CCSB 6.0= sold
2011 CCLB 350 dually lariat, 4x4, 6.7 all stock
95 ex cab long bed f250,4x4,7.3 auto with 4.10s and swamps tuning, 3 inch dp.for sale!!!
2002 ex cab long bed 4x4 7.3 auto. Stock and 294k on the clock.
geared_low550 is offline
post #8 of 16 (permalink) Old 06-25-2013, 05:01 AM
Diesel millwright
Re: Hypermax turbo
thats a great test setup idea, thanks for the info for future trouble shooting!
E99 f350 lariat scsb 7.3L auto, 8" lift, 37" toyos, 4" diamond exhaust, boost and egt gauges, bullydog gt, dp f6, L99 rear seat swap, K&N cold air kit, more to come
88 5.0L gt 5spd convertable, lowered, 17's, flowmasters, centerforce clutch, more to come
dealwithit is offline
post #9 of 16 (permalink) Old 06-25-2013, 11:31 AM
jtgf250's Avatar
Re: Hypermax turbo
Depends on what turbo was used and for what kind of install or purpose the truck was to be used for on when it spools up. Boost is low though.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #10 of 16 (permalink) Old 06-25-2013, 07:34 PM
Village Idiot
southmike's Avatar
Re: Hypermax turbo
My version of the boost leak detector - Diesel Forum - TheDieselStop.com
or buy one from dieselsite with full intructions...pretty straight forward though.
southmike is offline
