Southbend clutch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 10-14-2007, 03:03 PM Thread Starter
Southbend clutch
I am looking a getting a new cluch now that I put my Dp tuner in. I found that southbend makes a clutch 4 paddle 400hp and 900 ft lbs that goes on the stock flywheel. Would this be good for my towing setup. I read some where that it rattle under 1700 rpm. What is that about? Or should I just get the 350hp or 400hp kit with the flywheel?
Thanks
freshman is offline
post #2 of 27 (permalink) Old 10-14-2007, 03:43 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Re: Southbend clutch
All the single discs have full lining on them, not paddles that I'm aware of. And I think the DDs have either 6 or 12 buttons(paddles) on them, so not sure which one your talking about for the 4 paddle.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #3 of 27 (permalink) Old 10-14-2007, 04:02 PM Thread Starter
It is part #MU 1939 DF if that makes a difference.
freshman is offline
post #4 of 27 (permalink) Old 10-14-2007, 04:20 PM
<----Colin Banks
mattymx's Avatar
Southbend makes the best clutches around. talk with Peter there and he will set you up with what you need for your application. I love mine. 5 years and still ticking.
mattymx is offline
post #5 of 27 (permalink) Old 10-14-2007, 04:40 PM
OBS junkie
Cat_Rebel's Avatar
My buddy's have them in their truck's & love em.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 27 (permalink) Old 10-14-2007, 05:38 PM
2000 F350 SuperDuty 4x4
Calico5's Avatar
^^^^^^What he said!
My stocker started slipping when towing after I started adding some mods. It wasn't particularly worn...but it wouldn't hold in OD. I've been running a Southbend Double Disc now for about 2 years. LOVE IT! Absolutely no slipage.
Give Peter a call, and check 'em out at www.southbendclutch.com .
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #7 of 27 (permalink) Old 10-15-2007, 07:53 AM
Got Whistle?
crack_7.3's Avatar
I just put my con FE in tonight, the pedal is a bit softer and Ive only got about 25kms on it so im still breaking it in, but I have high hopes
08 F350 Lariat
Blacked
IDP tuned SCT
crack_7.3 is offline
post #8 of 27 (permalink) Old 10-16-2007, 12:38 AM Thread Starter
Well I called peter at southbend and he suggested an ofe with the fly wheel so I went and order one. The kind I was looking at from them that reuses the stock flywheel doesnt get a softer peddle and you have to put in helper springs on the clutch to be able to push it in.
When you guys put yours in did you install the new clutch fork?
freshman is offline
post #9 of 27 (permalink) Old 10-16-2007, 07:02 AM
Got Whistle?
crack_7.3's Avatar
I used the new cltuch fork, my old one wasnt that bad thoough.
08 F350 Lariat
Blacked
IDP tuned SCT
post #10 of 27 (permalink) Old 10-16-2007, 12:14 PM
Banned
They do make a paddle clutch. 4 Paddle with various button and material options. It does not use the Luk type pressure plate though, so it will not have that super soft pedal effort that you see with the Con FE for instance.
I feel that although people like to give me chit for my clutch (Johhnny...) it's a tough ass little SOB for a single. It's been getting over 1000ft/lbs of torque fed to it for nearly a year now and is still holdin up.
Mine is a 3 paddle with one decent sized ceramic button per paddle, per side.
Anytime you start trying to hold 1100 or so ft/lbs of torque on a single disc clutch while still using stock plate load (thanks plastic POS hydraulics) you're really pushing the single just as far as is possible.
In a month or so I hope to swap in a fluid coupler in it's place.
Can't go wrong with the guys at Southbend though.
Charles is offline
