Parts for mild performance upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 06-24-2013, 10:01 PM Thread Starter
ByrdDog's Avatar
Thinking of spending some $$$ on the 7.3. I'm happy with the truck as a daily driver in it's current configuration, but have recently purchased a 5th wheel (28 ft), and was wanting a little more power for towing. Here's what I was thinking; any feedback/suggestions would be great!
Stage 1's w/6-pos chip
WW2 - Would a ported housing be of much benefit?
RR? - Should I just do a RR, or go ahead & do upgraded pump & bowl delete?
HPOP - Do I need to upgrade, or will a good stock one be fine w/stage 1's?
High capacity trans pan? - does this really help?
6.0 trans cooler
2004 F350 CCLB 4x4 Dually - EGR Delete, Coolant Filter, 5" Exhaust, Evolution tuner/monitor, Leveling kit & 33's
1960 F250 4x4 - 400/C6
ByrdDog is offline
post #2 of 13 (permalink) Old 06-25-2013, 12:12 PM
jtgf250's Avatar
Re: Parts for mild performance upgrade
I would invest in a better valve body for the trans before spending the money on the bigger pan, I dont really see were its an advantage. Just holds more fluid, cost more to fill. Dont see were more fluid will keep it cooler, just take longer to warm up.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 13 (permalink) Old 06-25-2013, 03:45 PM Thread Starter
ByrdDog's Avatar
What kind of improvements will an aftermarket valve body provide? Sorry, I'm kind of ignorant on transmissions.
ByrdDog is offline
post #4 of 13 (permalink) Old 06-25-2013, 04:49 PM
look what i can do
1badpsd's Avatar
Aa
HPOP - Do I need to upgrade, or will a good stock one be fine w/stage 1's? stock is fine
High capacity trans pan? - does this really help?this-> Waste of money and actually keeps fluid hotter as its not able to circulate efficiently. Get a BTS valve body it firms the shifts and also tunes the trans you could say for the extra power.
6.0 trans cooler
1badpsd is offline
post #5 of 13 (permalink) Old 06-25-2013, 05:06 PM
6.0 trans cooler
I've got a 27' 5th wheel, weighs around 7500-8000lbs when loaded up. My personal recommendation would be a custom 6 position chip, 6637 DYI intake, and free up the exhaust (straight pipe is cheap as well), with gauges as the first mods. My PHP 80 Tow Tune is excellent and really moves the camper with ease while getting good MPG's.
I'd also recommend a Valvebody or the Tugger Shift Kit with a 6.0 Cooler as well.
Then I'd look into your other mods - injectors, WW2, RR, HPOP etc.
2002 F350 CC/SB 4x4
-PHP Hydra
-6637
-Straight Piped
bikeluver43 is offline
post #6 of 13 (permalink) Old 06-25-2013, 08:58 PM Thread Starter
ByrdDog's Avatar
Already got intake, exhaust & gauges; is my sig not showing up on my posts? On the 6.0 cooler, I recently saw a post on 1 for sale & there was a question on whether it was the 18 or 21 row one. Whats the deal there?
ByrdDog is offline
post #7 of 13 (permalink) Old 06-26-2013, 12:07 AM
The 6.0 cooler should be either 26 or 31 rows. I'm pretty sure the stock cooler on our trucks is 9 rows, so there is a huge difference when upgrading to the 6.0 cooler. I opted to get my cooler (26 row) from RockAuto because it was the lowest price, and I couldn't be happier. It does a really good job of keeping the temps in line.
If you PM me, I'll email you the install guide I used. It was very informative, and had quite a few pictures as well.
2000 F350 lariat, crew cab, long bed, 4x4, 3.73 limited slip
LASB turbo from Irate Diesel
4" exhaust
Gauges (EGT, Trans Temp, Boost)
AFE Stage 2 XP Pro Guard 7
DP Tuner F6 (no start, stock, 80e, 60e, 60t)
AIH delete and CCV mod
F650 Dash with Carling switches
2002 Headlights with FX-R HID bi-xenon projector retrofit and 50W 5000K bulbs
53fordguy is offline
post #8 of 13 (permalink) Old 06-26-2013, 04:42 AM
Village Idiot
southmike's Avatar
18 row might be a be v10 cooler..which is probably just fine and a direct Bolton...but better be way cheaper then the 26 row.
southmike is offline
post #9 of 13 (permalink) Old 10-04-2013, 04:14 PM Thread Starter
ByrdDog's Avatar
6.0 trans cooler installed
Got my 31 row cooler installed last week & towed my 5th wheel shortly afterwards.... WOW, what a difference! Last time I pulled it, trans temps got up to 240, this time it didn't even touch 180! Granted, the ambient temps were cooler this time, but i still think this is one of the best investments I have ever made for this truck.
ByrdDog is offline
post #10 of 13 (permalink) Old 10-04-2013, 06:53 PM
Bobs 7.3
Bobs 7.3's Avatar
Ive heard the 31 rows are really good for heavy towing but overkill if towing light (under 10,000) unless in the rockies. I always use the bigger is better rule though.
Bobs 7.3 is offline
