Injectors how much should I spend? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 06-21-2013, 10:18 PM Thread Starter
If I were to install riffraffs casserly full force 165's on my truck,
The price says 1195-800 core=400 correct, so if I were to send my stockers in to get built into 165s? is that the same price?
I tried givin them a call but didn't get a hold of them. is Riffraff here? maybe he could chime in?
Derristroke is offline
post #2 of 19 (permalink) Old 06-21-2013, 10:21 PM
38R turbo's Avatar
Re: Injectors how much should I spend?
I would say it is $1195 + $800 core = $1995. You get $800 back when you send In your old injectors.
2000 F250 CC SB 4x4, 7.3 diesel, 4R100, 4"lift, AIS intake, 38R Turbo, Turbonetics outlet, Swamps 200/30 Hybrids, Swamps tunes, Swamps IDM, 4" MBRP, BTS valvebody, 6.0 cooler, ISSPRO fuel press, boost, egt, trans, water temp, ScanGage, Melling Lpop, FRx, Hutch mod, spin on filter/separator, Bosch pump, DIY 3/8 fuel lines, OCR, HPx, Autoenginuity.
38R turbo is offline
post #3 of 19 (permalink) Old 06-21-2013, 10:28 PM Thread Starter
figured it'd be more than i said ha
post #4 of 19 (permalink) Old 06-21-2013, 10:49 PM
Rustbucket
data_engine's Avatar
I'd go through the posts and info here in this forum, and get a really good feel for what's involved. There are so many good posts by experts here on the minutiae of injector swaps. I have stock ones right now, but still haven't decided on what I want to go with.
"Lets Eat Grandma!"
"Lets Eat, Grandma!"
Commas Save Lives!
1999.5 F350 7.3 PSD Auto, 8" Lift, Nitto 38s, Hutch" Mod, AIH Delete, Fuel Pressure, Pyro & Boost Gauges, 4" Magnaflow turbo down, Riffraff Intake, Grand Rock 5" single stack, TS 6 Pos Chip
data_engine is offline
post #5 of 19 (permalink) Old 06-23-2013, 06:02 AM
SledDogg's Avatar
Fullforcediesel.com
160 cc stage 2 with 100% nozzles. I have stock nozzles that I'm soon sending back to get 100%(better egt control). Also can get a 6 position chip with Matt Robison Gearhead tunes for an extra $400. Add a Diesel Site Billet Wicked Wheel II $229. And hold on!!!!
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #6 of 19 (permalink) Old 06-24-2013, 09:11 PM
PM sent.......
WHO said 100% nozzles get you better egt control?
email:
Website:
OBSWIZ is offline
post #7 of 19 (permalink) Old 06-25-2013, 02:33 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Originally Posted by OBSWIZ View Post
PM sent.......
Anytime you can shorten the injection event you can get lower EGT's... Its not a hard concept to grasp.
Joe
CSIPSD is offline
post #8 of 19 (permalink) Old 06-25-2013, 04:19 AM
SledDogg's Avatar
PM sent.......
[email protected] No Limit Tuning Design
Matt Robinson @Gearhead Automotive
Ryan Casserly & Matt @Full Force Diesel
Is this enough Corey???
They all said the same as CSIPSD.....can tune for same current hp/tq but liwee the egt from injecting fuel later/faster.
SledDogg is offline
post #9 of 19 (permalink) Old 06-25-2013, 04:27 AM
CSIPSD's Avatar
"later" might not be the correct word... At the correct time and over a shorter time frame is more specific.
With a smaller nozzle the PW has to be stretched out in order to inject the correct amount of fuel for the HP requested. Only so much can be injected later, so more has to be injected earlier. Ideal SOI doesnt change, just the give and take needed to inject the fuel.
Larger nozzles correct this issue.
With that comes lower duty cycles and less HPO used...
Joe
CSIPSD is offline
post #10 of 19 (permalink) Old 06-25-2013, 04:40 AM
SledDogg's Avatar
Later in relation to current stock nozzles. As you stated it'll dump fuel quickly. Surprised Corey questioned it, unless he was assuming that I meant lower egt and more Power ..not possible.
SledDogg is offline
