Injector options, nozzles? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-20-2013, 05:52 PM Thread Starter
Diesel millwright
Hey guys, I'm wondering if someone might have some insight on injector nozzles and sizing. I have a 99 7.3, I'm wondering about an injector upgrade down the road. I read on here about just changing to larger nozzles for more fuel? Also would a turbo or injectors be first in order as a list of modifications? Thanks for any help/advise
dealwithit is offline
post #2 of 8 (permalink) Old 06-20-2013, 06:40 PM
Billy Big Rigger
smoking69's Avatar
Re: Injector options, nozzles?
Do you have an Early 99 or a late 99?(Where are the powerstroke badges, and does it say "INTERCOOLED" on the airbox lid? As for Injectors, a stage 2 (160cc, 80 or 100 over) is about all you can run with stock HPOP unless going to hybrids. To run bigger injectors that are split shots you need a custom tuned chip. A bigger turbo will not help without adding more fuel(chip and injectors)
smoking69 is offline
post #3 of 8 (permalink) Old 06-20-2013, 06:40 PM
the stryker god
No way I would waste the time or money to put nozzles on a set of ad's IMO I think that a stock injectored truck with more air is more practical than a big injector truck on stock air
bruce51d is offline
post #4 of 8 (permalink) Old 06-20-2013, 08:26 PM Thread Starter
Diesel millwright
Hmm I don't have an air box lid anymore, I do have the vin # with me, but the truck is far away at the moment. I would have no problem going to single shots, if that's beneficial. I guess getting 300rwhp on the stock sticks wouldn't be a problem? Or is that pipe dreams? I do have a f5 chip for it, so an adjusted tune wouldn't be a problem. Any ideas at about what size injector/nozzle does it start to effect idle or other areas of normal engine operation? Or is that mostly in the tuning? Thanks again guys.
post #5 of 8 (permalink) Old 06-20-2013, 08:52 PM
the stryker god
you can make 300 on stock injectors. by more air i mean bigger turbo. you need to figure out how much hp you want to make before i can really help you
bruce51d is offline
post #6 of 8 (permalink) Old 06-22-2013, 08:24 PM Thread Starter
Diesel millwright
Under 400 would be my end number down the road. That shouldn't be to much to ask of this motor and still be reliable? It does have 270k miles on it, unsure if it was ever replaced but I doubt it. I'll be plenty content with 300 for awhile, this trans was redone recently, the only info I really have at the moment is that it was upgraded when it was rebuilt (no big diesel places around here so I think it's just like a shift kit and what not) but I'm just thinking of it as a stock setup. Would 300 on the factory turbo be pushing it to far?
E99 f350 lariat scsb 7.3L auto, 8" lift, 37" toyos, 4" diamond exhaust, boost and egt gauges, bullydog gt, dp f6, L99 rear seat swap, K&N cold air kit, more to come
88 5.0L gt 5spd convertable, lowered, 17's, flowmasters, centerforce clutch, more to come
post #7 of 8 (permalink) Old 06-22-2013, 08:33 PM
A stock turbo will do 300. A little upgrade to it would be a billet wheel. If you seriously plan on going bigger though invest in an h2e. That way you can just get it modded when you go bigger.
At least that's the path I wish I took.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #8 of 8 (permalink) Old 06-22-2013, 08:58 PM
Swamped
For 400 HP...
If its a late 99 - 160/100's, 38r.
If its an early 99 - 160/100's, D66.
2012 F350 6.7 Lariat - Stock for now
1999 F250 7.3 Lariat - Up for sale soon
chris1978 is offline
