Srp1.1 or t-500 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 78 (permalink) Old 06-19-2013, 06:29 PM Thread Starter
Srp1.1 or t-500
Which one is better for 238cc 100% hybrids. With room to grow! Planning on 300cc 200% in the near future.
ibleeddiesel is offline
post #2 of 78 (permalink) Old 06-19-2013, 07:09 PM
the stryker god
Re: Srp1.1 or t-500
Definitely srp1.1
bruce51d is offline
post #3 of 78 (permalink) Old 06-19-2013, 07:53 PM
zilla68's Avatar
Re: Srp1.1 or t-500
is the stage 1 and stage 2 pumps the same price? I see they say over 200cc injectors you need the stage 2 pump.
also, on the obs, it says fuel bowl must be relocated. I am sure most guys would be running efuel anyways, but if you did have the stock bowl, I wonder how much relocating is needed.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #4 of 78 (permalink) Old 06-19-2013, 10:12 PM
this $hit is expensive!
ccf350stroker's Avatar
Re: Srp1.1 or t-500
If you plan on gettin into those 300's go with srp, much better pump with larger injectors. My t500 works well with my 250/100's but id say a 250/200 would top out the t500. Plus I think stealth offers a pretty nice warranty now if im not mistaken.
97 f350 cclb 7.3 5 spd on 35's, ffd 250/100's, s465 turbo, irate t4 mount, 3 inch plenums, t-500 hpop, arp's, sb pushrods, comp 910's, gearhead tunes, e fuel, and valair dual disk clutch
ccf350stroker is offline
post #5 of 78 (permalink) Old 06-19-2013, 10:31 PM
Busy Busy
Marty's Avatar
Re: Srp1.1 or t-500
I use the SRP1.1 for setups like that. However getting pumps has been an issue. I have only installed a few T500's and they were all on >250cc so I can't comment on 300cc injectors.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #6 of 78 (permalink) Old 06-19-2013, 10:34 PM
Busy Busy
Marty's Avatar
Re: Srp1.1 or t-500
Any 17* style pump that is in good shape will work with 238's......
Elkton, Maryland
Marty is offline
post #7 of 78 (permalink) Old 06-19-2013, 10:43 PM
Village Idiot
southmike's Avatar
Re: Srp1.1 or t-500
For 238 I would do a t500 or adrenaline .
For 300 I would ask bob about the adrenaline it may need more
I would ask joey about a t1 or twins at that level...
Also send thuglike a pm I believe no limit has something in the works.
Probably similar to the gen 2 stealth bean had for a bit if I guessed. ... ut that is pure speculation.
Too many srp failure to trust that on a dd.....however that may have been corected
southmike is offline
post #8 of 78 (permalink) Old 06-19-2013, 11:07 PM Thread Starter
Re: Srp1.1 or t-500
alrighty, iv been looking for awhile i modded my own 17* pump to have a lttle more output but. im planning on going with a bigger set of injectors pretty soon. it will not be my dd its gunna be my sled truck my goal is a relaible 600+. but thanks for the info.
post #9 of 78 (permalink) Old 06-19-2013, 11:15 PM
Re: Srp1.1 or t-500
I'd talk to Joey and see what he says. His pumps have proven to be ultra reliable and his customer service is hard to beat. Im sure the Srp is a good pump but I have heard of a few failures myself. DD or not who wants to change pumps for fun......ok we do but just sayin lol
14fan77 is offline
post #10 of 78 (permalink) Old 06-20-2013, 03:29 AM
m j
m j's Avatar
Re: Srp1.1 or t-500
so what makes a t500 anything other then a used 17 pump?
hpop is a fixed displacement pump so if you aren't making the stroke longer or the bores larger you arent doing very much.
i ordered an srp1.1
m j is offline
Closed Thread
