Computer code compatibility? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 06-18-2013, 03:03 PM Thread Starter
Diesel millwright
Hey guys, so I'm wondering a couple things here to do with chip programming and ecu codes. I have a 99 7.3 (not sure early or late, I do have the vin code if that helps, truck is 5hrs away at the moment, do not know the ecu code) and I picked up a dp f5 with tunes for a 02 7.3 for a sweet deal hoping it would cross over, if not it will be easy to resell or retune if need be. So I'm wondering anyone might have an idea on what computer code I have, and what codes might work with other code tunes? Thanks guys
Ken
dealwithit is offline
post #2 of 19 (permalink) Old 06-18-2013, 03:50 PM
the stryker god
Re: Computer code compatibility?
Why don't you just pull the ecm and look
bruce51d is offline
post #3 of 19 (permalink) Old 06-18-2013, 03:53 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
It will not just drop in and work. 99-2001 will more or less work fine, auto to auto and such. There was a major change in 2002-2003 and the chip will not work without a reburn.
Joe
CSIPSD is offline
post #4 of 19 (permalink) Old 06-18-2013, 05:44 PM Thread Starter
Diesel millwright
If I could pull it there wouldn't be a problem, the issue is that I'm not near the truck for 2 weeks.
Ok, that's what I was starting to think the more I looked into it... Thanks
post #5 of 19 (permalink) Old 06-18-2013, 10:09 PM
Village Idiot
southmike's Avatar
reburn or resell..
southmike is offline
post #6 of 19 (permalink) Old 06-21-2013, 07:41 AM
tbolt's Avatar
if it's an e99 with oem pcm thats another story. If it is upgrade to a pmt and have Jody put new tunes in the f5. Mine runs & tows really well.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #7 of 19 (permalink) Old 06-21-2013, 08:38 PM
Village Idiot
southmike's Avatar
Jody can tune e99s...too.
post #8 of 19 (permalink) Old 06-22-2013, 08:18 PM Thread Starter
Diesel millwright
Oh? What's the early ecu code? L99-01 is all pmt 1-2-3 right?
E99 f350 lariat scsb 7.3L auto, 8" lift, 37" toyos, 4" diamond exhaust, boost and egt gauges, bullydog gt, dp f6, L99 rear seat swap, K&N cold air kit, more to come
88 5.0L gt 5spd convertable, lowered, 17's, flowmasters, centerforce clutch, more to come
post #9 of 19 (permalink) Old 06-24-2013, 04:16 AM
Village Idiot
southmike's Avatar
Oh no there are lots of different codes...sheets of them. Fewer families.
My original pcm was an xle
...my chip is written for an Nvk
For example. Ill leave it to the tuners to explain more.
post #10 of 19 (permalink) Old 06-25-2013, 02:40 AM Thread Starter
Diesel millwright
oooh gotcha. does anyone know if any damage can occur running a chip with a wrong tune, or if it just wont work/run etc.
