New Gauges, Proper Numbers? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 06-18-2013, 05:59 AM Thread Starter
Question New Gauges, Proper Numbers?
Hey guys,
Well I just wrapped up installing my new Glowshift gauges (I know, not the best brand, but they were recommended to me at the time). So far they are functioning great, and I just had a few questions for anybody else who is running gauges. I am trying to decide if I am getting reasonable numbers on the gauge. About the truck: 2000, F-250, 130,xxx miles, Napa 6637 intake, stock tires, exhaust (for now ) pretty minor mods so far.
Outside air temp was 67 degrees while I was testing
The truck is my daily driver, no towing or heavy loads for the most part.
At idle, EGT reads roughly 250, boost 0
At WOT EGT reads roughly 900, boost 16 (about 3100 RPM)
At 60 mph, EGT runs anywhere from 400-500 degrees depending on if I am going up or down hills or on level ground. Boost sits right at 4 PSI.
On a 15 mile test run, trans temp ran up to 140 at the most.
I thought the boost seemed low, so I ran another test with the boost line hooked up to a tester, and also got 15-16 PSI. Do these numbers seem to be pretty much in range for my setup? Any feedback would be much appreciated!
RTC Powerstroke is offline
post #2 of 15 (permalink) Old 06-18-2013, 06:11 AM
FL-DIESEL's Avatar
Re: New Gauges, Proper Numbers?
tunes?
2002 7.3 stabbin waggon ... 4in turbo back, cold air, autometer pillar, dp-tuned...more to come, feel free to make donations
FL-DIESEL is offline
post #3 of 15 (permalink) Old 06-18-2013, 06:31 AM Thread Starter
No tunes yet, gonna get my exhaust in first and then go from there. Sorry if this topic has already been covered somewhere, I did a little digging on the forums and couldn't find what I was looking for.
post #4 of 15 (permalink) Old 06-18-2013, 06:38 AM
jtgf250's Avatar
Were did you install the egt probe? That sounds way low for WOT. and so does boost. You may have a leak. Your egt temps seem low across the board to me.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #5 of 15 (permalink) Old 06-18-2013, 06:42 AM
FL-DIESEL's Avatar
your vitals seem pretty normal for stock tune... boost seems a little low... but if your "exhaust" is staight pipe with 4 in down pipe then that seems reasonable....
post #6 of 15 (permalink) Old 06-18-2013, 06:44 AM Thread Starter
EGT Probe is drilled and tapped right into the exhaust manifold, where the manifold collects and kind of does an S shape. I was suspecting a boost leak also because I am pretty sure that I have a slight oil leak going somewhere on the turbo pedestal. Now it was pretty much just hitting WOT briefly, I didn't hold it there for too long. Is it possible I pushed the probe too far into the manifold? I pushed it in until it hit the opposite side, then pulled it back about 1/8"
post #7 of 15 (permalink) Old 06-18-2013, 06:45 AM
FL-DIESEL's Avatar
stock tunes.. mine runs about 980 egt wot... 20 psi tops.... around 6-8 psi on cruise....
post #8 of 15 (permalink) Old 06-18-2013, 06:48 AM
jtgf250's Avatar
Ok well if not in it very long I can see 900 but an oil leak at the turbo wouldnt be a boost leak. Look for soot around pipe flanges and such. Was just making sure you were in the manifold.
jtgf250 is offline
post #9 of 15 (permalink) Old 06-18-2013, 06:50 AM
jtgf250's Avatar
I definatly go over 20 psi and 980 egt.
jtgf250 is offline
post #10 of 15 (permalink) Old 06-18-2013, 06:55 AM
FL-DIESEL's Avatar
with my dd tune im pulling around 26psi & 1100 wot depending on OAT.... turned all the way up im doing around the same psi give or take a few pounds... egts are a bit higher
