AERO HEADLAMPS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 01-14-2009, 08:14 PM Thread Starter
AERO HEADLAMPS
Has anyone changed headlamps on a Superduty truck from the regular headlamps to the Clear Aero type lights. What all do you need to do this and how do you change the wiring connectors? Any help would be greatly appreciated. 2001 F250
kip4234 is offline
post #2 of 14 (permalink) Old 01-14-2009, 08:31 PM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Re: AERO HEADLAMPS
Do you mean to the 05 style? Or something else aftermarket?
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #3 of 14 (permalink) Old 01-14-2009, 08:35 PM Thread Starter
Re: AERO HEADLAMPS
yes like the newer factory ones
kip4234 is offline
post #4 of 14 (permalink) Old 01-14-2009, 08:39 PM Thread Starter
Re: AERO HEADLAMPS
And which truck came with the clear lens???????????????????? Thanks
kip4234 is offline
post #5 of 14 (permalink) Old 01-14-2009, 09:40 PM
Supercharged
Re: AERO HEADLAMPS
02 - 04 have two piece clear headlights.. direct fit into your 2001.. 05 - 07 have one piece headlights... To install these you either need to cut your header panel or replace it.
The headlights in the pic below are 05 - 07's they will fit in your 2001 if you cut the header panel.
Oil- Swamps Gen-3
Fuel - B-codes
post #6 of 14 (permalink) Old 01-14-2009, 09:51 PM Thread Starter
Re: AERO HEADLAMPS
Rockrunner is this hard to do. How do you cut it and how about wiring for the different bulbs
kip4234 is offline
post #7 of 14 (permalink) Old 01-14-2009, 09:52 PM Thread Starter
Re: AERO HEADLAMPS
Rockrunner How and what do you do to cut the Header panel?????? and what about wiring for the headlamps??????
kip4234 is offline
post #8 of 14 (permalink) Old 01-14-2009, 09:59 PM
Supercharged
Re: AERO HEADLAMPS
There is some write ups online about how to cut the header panel. I don't know where to locate them. Maybe someone else will chime in. I didn't worry about the wiring. I am just going to direct wired the Hid's I install so they don't use the wiring plug.. If you had your headlight removed and the 05 lights in hand you would see what needs to be removed.. Its pretty simple. I think all the cutting took about 10 minutes for the first light. I used a grinder with a cut off wheel for most of it. But anything that would cut fiberglass would get the job done.
Oil- Swamps Gen-3
Fuel - B-codes
post #9 of 14 (permalink) Old 01-14-2009, 10:06 PM Thread Starter
Re: AERO HEADLAMPS
What is different in 05-07 Regular and Harley Lights???????? And if anybody knows what you do to cut header please respond thanks
kip4234 is offline
post #10 of 14 (permalink) Old 01-14-2009, 10:22 PM
Supercharged
Re: AERO HEADLAMPS
Only difference between the lights is if they have a chrome back bround or black..
Oil- Swamps Gen-3
Fuel - B-codes
