Nitrous? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 06-16-2013, 06:27 PM Thread Starter
Nitrous?
Hey guys was looking into getting a nitrous kit and I was wondering what is needed mod wise to support the use of nitrous ARP head studs will be installed if I decied to get a kit
Thanks
2000 F250 SCSB 6-speed, stage 3 clutch, lifted 4'' with 37's, 5er, 4'' turbo back, 6637 intake, STAGE II Rosewood singles, PHP Phoenix chip, 38R, 910"s shimed, Traction Bars.
05/12_288.64 RWHP. 575.04 FT-LBS-TQ
JUST DYNOED! 411 HP 794 FT-LBS-TQ
RLSCOAL is offline
post #2 of 14 (permalink) Old 06-16-2013, 06:47 PM
the stryker god
Re: Nitrous?
Valve springs and pushrods. Maybe an aftermarket waste gate actuator
bruce51d is offline
post #3 of 14 (permalink) Old 06-16-2013, 10:11 PM Thread Starter
Re: Nitrous?
Thanks Bruce51d
RLSCOAL is offline
post #4 of 14 (permalink) Old 06-17-2013, 04:52 AM
Re: Nitrous?
You shouldn't need nitrous with stage 2's and 38r, I doubt you gain much.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #5 of 14 (permalink) Old 06-17-2013, 07:03 AM
PSD
CNDiesel's Avatar
Re: Nitrous?
i gained roughly 100rwhp with a single .125 shot on a stock injector truck. i wouldn't play down nitrous effects as not gaining much...
as said before headstuds, springs, even a bigger waste gate would be something to look into
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #6 of 14 (permalink) Old 06-18-2013, 12:09 AM
Village Idiot
southmike's Avatar
Re: Nitrous?
go ask that question on power stroke army web site...more guys use nitros there and can give you 100% answers and kit recommendations etc..
just don't reenact any of dockboy's results.
southmike is offline
post #7 of 14 (permalink) Old 06-18-2013, 01:45 AM Thread Starter
Re: Nitrous?
ok thanks guys I still have smoke that im tryng to clean up still looking of leaks of course first but was just dreaming I figured it would be cool to get up too 600 hp with a shot of nitrous after adding some hybrids of course
RLSCOAL is offline
post #8 of 14 (permalink) Old 06-19-2013, 06:32 AM
Diesel millwright
Re: Nitrous?
hmmm a second turbo maybe? if trying to clean up smoke and make more power...
dealwithit is offline
post #9 of 14 (permalink) Old 06-19-2013, 11:15 AM
jtgf250's Avatar
Re: Nitrous?
Well I noticed its a 2000. I'ld check what rods you had in that thing first and also look at hpop. Stage 2s and 38r I would think you would already be over the 300 mark. Your talking about double horses, gonna need to change that turbo most likely also.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #10 of 14 (permalink) Old 06-19-2013, 11:16 AM
jtgf250's Avatar
Re: Nitrous?
Well I noticed its a 2000. I'ld check what rods you had in that thing first and also look at hpop. Hpop may not be keeping up. Stage 2s and 38r I would think you would already be over the 300 mark. Your talking about double horses, gonna need to change that turbo most likely also.
jtgf250 is offline
