Best place to get intercooler boots? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 06-16-2013, 04:51 PM Thread Starter
powerstrokin44's Avatar
I have a 66 h2e and 250/100, and my intercooler boots keep blowing off ever since I ran it at the track last night and it blew off between the 1/8th and quarter. So its time to get some new boots and clamps. What is everyone running and where can I get a good boot???
2000 F-250 Stroker, Cale's tunes, modded H2E, Full Force 250/100, Built tranny from John Richmond, Precision converter, Manley rods, Mahle pistons, clevite bearings, girdle, sbi valves, a1000, Comp springs, Smith bros pushrods, billet plenums, DI RR.
powerstrokin44 is offline
post #2 of 26 (permalink) Old 06-16-2013, 05:16 PM
Re: Best place to get intercooler boots?
riffraff diesel i send all my business to. if you need some odds and ends then check out Air to Water Intercooler
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #3 of 26 (permalink) Old 06-16-2013, 06:48 PM
the stryker god
Dieselsite
bruce51d is offline
post #4 of 26 (permalink) Old 06-17-2013, 07:39 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
RiffRaff Diesel...
Riffraff Diesel: RDP Complete CAC Intercooler Boot Kit 99-03
Joe
CSIPSD is offline
post #5 of 26 (permalink) Old 06-17-2013, 08:23 AM
tbolt's Avatar
Dieselsite
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #6 of 26 (permalink) Old 06-17-2013, 11:35 AM
KCMEADOWS's Avatar
Dieselsite
2008 F-350 4x4 cclb dually fully deleted w/flo-pro 4" duals, elbow, cold side pipe, h&s mini maxx
-Built Not Bought-
KCMEADOWS is offline
post #7 of 26 (permalink) Old 06-17-2013, 12:07 PM
CSIPSD's Avatar
I had the dieselsite boots and while they worked fine, the ones Clay is selling are 10 times better, cleaner and overall better looking.
Joe
CSIPSD is offline
post #8 of 26 (permalink) Old 06-17-2013, 03:13 PM
Bobs 7.3
Bobs 7.3's Avatar
I used the Dieselsite boot kit as the riffraff kit is made of silicone (the same as the stock factory boots that break down over time).
Bobs 7.3 is offline
post #9 of 26 (permalink) Old 06-17-2013, 11:19 PM
Village Idiot
southmike's Avatar
clays boots are cheaper in everyway. quality, fit etc.
.....as with most of his knockoffs err products.
dieselsites are higher quality, a better fit and will last ten times as long.
southmike is offline
post #10 of 26 (permalink) Old 06-18-2013, 07:46 AM
CSIPSD's Avatar
Wow... You just went there?
Please educate me as to what products are a knock off?
His boots are FAR better then the ones I had on my truck. But wait, I have had both products... Humm how could I give a opinion on something I have used, and installed on several trucks?
Not knocking Bob's, they worked fine for me, however they were straight boots, with no bellows and no give. They loved to blow off my turbo at about 40psi (I have the dent in my hood from it happening over and over). They were more or less just cut pieces of heavy hose.
Clays are made for our trucks, bellowed where they need to be for flex and have yet to blow off at 55psi. Single clamped now rather then double clamped like the Dieselsite boots.
What other "knock off" product are you referring too... And careful what you say, because I have been testing off and on for Clay for about 18 months now...
Joe
CSIPSD is offline
