Used Garrett 38r what do I look for? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-12-2013, 11:48 PM Thread Starter
I have found a used 38r that a guy "bought for his dodge but found it wouldn't work". Other than the obvious, marks on the fins, slop on the shaft. What do I need to check for before buying? It's priced at $400.
Nate99 is offline
post #2 of 5 (permalink) Old 06-13-2013, 01:41 AM
dsberman94's Avatar
Re: Used Garrett 38r what do I look for?
Make sure there's normal shaft play. Ball bearing turbos have small amounts of shaft play until the bearing is filled with oil. Very minute amounts of play are normal but a millimeter too much and you're going to be buying another turbo in 20-50 thousand miles. If you want more information try Garrett's website. They tell all about they're turbos and what is normal.
dsberman94 is offline
post #3 of 5 (permalink) Old 06-13-2013, 01:46 AM
300,000 and counting's Avatar
Make sure it's a 38r and not just a factory one
2001 7.3 PSD, Swamps 200/30 injectors, 38r turbo, HPx, FRx, bellowed up-pipes, non-ebpv ped, Gearhead tuned TS 6 pos chip, AFE big boost intake, 4" downpipe; 5" exhaust, BTS valve body, 31 row tranny cooler, autometer gauges, 05-07 front end, centurion rear bumper, 327,000 miles FOR SALE
2009 6.4 PSD, 71mm LP, studded, delete, H$S Mini Max
300,000 and counting is offline
post #4 of 5 (permalink) Old 06-13-2013, 06:11 AM
400 for a 38r seems awfully cheap to me. Hope it is one and hope its in good shape for ya but just be aware that when it does wear out its gonna cost you more than double what you paid to have it fixed. But if you can get 50000 miles out of it , 400$ is a good deal for the performance you get.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #5 of 5 (permalink) Old 06-13-2013, 04:33 PM Thread Starter
Thanks for the info
Nate99 is offline
