So... what should I buy next? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 01-11-2009, 07:19 AM Thread Starter
Braaaaaaaaaaaap
Dysfunctional's Avatar
Budget - $2-3k
Primary use - TOWING
I gross around 20k lbs when towing and sometime in the future (next couple years?) that will go up when I acquire some more luxurious amenties for trips
I think the obvious choices are: big oil, single shots, fuel system, CAC, head studs, toss the TN 1/2 Baller? So I'm asking for opinions... what next?
I'm not looking to go crazy and have a race truck, reliability and functionality are priority one to me.
'00 F350 CC LB 4wd 7.3L with stuff, haulin' a 40' trailer with toys
Dysfunctional is offline
post #2 of 15 (permalink) Old 01-11-2009, 04:20 PM
matthewd11's Avatar
Re: So... what should I buy next?
if that is your list, 3k will not cut it, unless you make your own fuel system and HPO system.
matthewd11 is offline
post #3 of 15 (permalink) Old 01-11-2009, 05:54 PM
Proud PSN Sponsor
Deputydog's Avatar
If you're towing, I wouldn't get too crazy with injectors. Stock AD's will serve you well. I would however suggest big oil. That along with stock injectors work pretty well for towing. Not sure you need to upgrade your turbo unless you get more fuel at this stage.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #4 of 15 (permalink) Old 01-11-2009, 06:27 PM
Back to Civilian Life!!
MILFORD's Avatar
I would say big oil with a fuel system first.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #5 of 15 (permalink) Old 01-11-2009, 07:08 PM
ELKHUNTER's Avatar
Small hybrids with stock nozzles, keep the turbo, skip the oil and fuel system and maybe water injection instead of CAC. Injectors are gonna eat up 2000.00 to 3000.00.
Josh
2000 F350 205,000
STAGE II SPLITS 100%
STEALTH SRP1
TYRANT TUNES
38R TURBO
BTS VALVE BODY
WALBRO 392
SCANGAUGE
ISSPRO
MORE STUFF
ELKHUNTER is offline
post #6 of 15 (permalink) Old 01-11-2009, 07:32 PM
HP Junky
Big oil
RockinJW is offline
post #7 of 15 (permalink) Old 01-11-2009, 08:53 PM
<---Beer version of PMR's
Seven3Leeter's Avatar
You have an excellent turbo for towing, I'd keep it. Big oil and a cac and you'll have killer setup, if your AD's are in good shape. If not I'd do AC's and a cac. May want to look into other good tow mods like exh.brake, rear swaybar, airbags, ect. Should be an awesome rig! 'leeter.
Tuning by Sniper
Transmishing by John Wood
Breathing by AFE
Exhausting by Pinncle
Monitoring by me and Isspro
Compressing by Wicked Wheel
Wasting by Turbomaster
Stopping by Powerslot
Lifting by Donahoe
Rolling by Toyo
Protecting by Ranch Hand, God, and Ruger
Addiction by
[SIGPIC][/SIGPIC]
by Garrett, Alliant, ITP, DP-Tuner
Seven3Leeter is offline
post #8 of 15 (permalink) Old 01-11-2009, 10:29 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
My opinion would be small hybrids, stock nozzles, about 200cc. Fuel system to feed them, or water injection for towing. That would be one badass towing setup.
Stock
PowerstrokeJunkie is offline
post #9 of 15 (permalink) Old 01-12-2009, 04:21 AM Thread Starter
Braaaaaaaaaaaap
My intent wasn't to buy that entire list for 3k... just listing the things I could buy.
Is big oil going to make that much of a difference with stock injectors?
post #10 of 15 (permalink) Old 01-12-2009, 04:45 AM
<----Colin Banks
mattymx's Avatar
With the proper tuning to make use of all the ICP the big oil can provide, that would make for a great running truck.
mattymx is offline
