Another Surge/Turbo Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 01-09-2009, 03:36 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Well, I pulled the turbo, took it apart, and found that the fins of my compressor are pretty eaten up... kinda scary really...
Also, I don't know the exact name, but the area behind the compressor wheel, the "inside" of the compressor, was scarred up and there's some cracks and trash from the casting process. They're not "deep" cracks, so no worry about leaks, but anyway, I took the roughness off of it all and polished it out... hope that's OK...
My real question is,
Do I need to worry? It all looks good now. Are the cracks common? Like I said, they're not big or deep, just kinda look like spider veins or something.
Could the dull wheel be the cause of my surge? Thanks for all the help guys!!!!
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #2 of 29 (permalink) Old 01-09-2009, 03:42 PM
Snake Oil Salesman
mattr66's Avatar
Re: Another Surge/Turbo Question
if the fins are touching the housing sounds like it is time for a rebuild and a WW before it ruins your housing or upgrade to 38r....
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #3 of 29 (permalink) Old 01-09-2009, 03:44 PM
Lovin the Tuna
RedSmokey's Avatar
How is the shaft play on the turbo? Does sound like you might need to rebuild the turbo if the wheel is hitting the housing, thats definitly to much shaft play...
2001 F250
2000 F250
RedSmokey is offline
post #4 of 29 (permalink) Old 01-09-2009, 04:07 PM
Snake Oil Salesman
mattr66's Avatar
RedSmokey means the turbo not you.....
Matt Robinson
mattr66 is offline
post #5 of 29 (permalink) Old 01-09-2009, 04:13 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
No! There's no contact to the housing... should have taken pics!! I'll find a pic of one and show you. There's virtually NO shaft play!
Alex.... You and the shaft play.... You'll go blind!!
228-365-0698
post #6 of 29 (permalink) Old 01-09-2009, 04:15 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Can't make it work right....
228-365-0698
post #7 of 29 (permalink) Old 01-09-2009, 04:19 PM
fbilly420's Avatar
The cracks are normal nothing to worry about. If there is no shaft play just throw the wheel on and go.
Pic no workie.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #8 of 29 (permalink) Old 01-09-2009, 04:25 PM
Caption This
444-4D's Avatar
If the wheel isn't on it there will be some play.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #9 of 29 (permalink) Old 01-09-2009, 04:37 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Area "H". I polished all the rough spots and there's some cracks in there.
228-365-0698
post #10 of 29 (permalink) Old 01-09-2009, 04:57 PM
Lovin the Tuna
RedSmokey's Avatar
seems good to me then... and sorry about all the shaft play , im still feeling the affects of last night, i had little to much wild turkey 101 and not enough sleep
2001 F250
2000 F250
