Need good advice on radiator - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-04-2013, 02:35 PM Thread Starter
Radiator went bad allowing water into the transmission.
I ordered a performance radiator 2171.
But think it would be good to just use a radiator that doesn't cool the transmission also, and get an air cooled transmission cooler.
How do I prevent this from happening on a budget.
Do you think 400-500 miles on water in the tranny means it will need a complete overhaul?
Thanks,
FL_93_7_3L_Excursion is offline
post #2 of 6 (permalink) Old 06-05-2013, 12:20 AM
SledDogg's Avatar
Re: Need good advice on radiator
Through a commercial account and a Ford dealership I paid two hundred and sixty nine dollars for a brand new Ford radiator. Diesel site sells it true cool 40,000 GVW trans cooler for like a hundred thirty five bucks. make sure you completely clean your intercooler while the radiator is out. My entire intercooler was 100 percent blocked off causing my overheating issue. I spent two hours with the special water attachment getting it clean. I can load this thing down 21 thousand pounds strong running grade and high speed in my temp gauge doesn't budge.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #3 of 6 (permalink) Old 06-05-2013, 12:27 AM
I dont know why I cant find it now, but i got a 6.0 trans cooler from rock auto for about $200
2000 F350 lariat, crew cab, long bed, 4x4, 3.73 limited slip
LASB turbo from Irate Diesel
4" exhaust
Gauges (EGT, Trans Temp, Boost)
AFE Stage 2 XP Pro Guard 7
DP Tuner F6 (no start, stock, 80e, 60e, 60t)
AIH delete and CCV mod
F650 Dash with Carling switches
2002 Headlights with FX-R HID bi-xenon projector retrofit and 50W 5000K bulbs
53fordguy is offline
post #4 of 6 (permalink) Old 06-05-2013, 02:11 AM
SledDogg's Avatar
For $200 it wasn't the 31 row I bet. Probably the smaller 26 row 6.0 cooler. And Tru Cool is a far better cooler. It is a stand alne 40,000 gvw cooler.......plate style as well.
SledDogg is offline
post #5 of 6 (permalink) Old 06-06-2013, 03:09 PM
Caption This
444-4D's Avatar
A 6.0 cooler is a Tru Cool cooler. The difference is the aftermarket one is only half the size of the OE one. So if a 13 row Tru Cool is rated at 40,000 GVW a 26 row 6.0 cooler should be rated at 80,000 GVW.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #6 of 6 (permalink) Old 06-06-2013, 11:32 PM
Village Idiot
southmike's Avatar
the 31 is larger the 26 is more efficient..so they are a wash. a v10 is a good cheaper direct Bolt on as is the tru cool...
the reason they added the tranny cooler to the radiator is for trucks that idle a lot. do a lot of backing and slow traffic use etc...my early 99 does not have it.
southmike is offline
