Fuel sump question? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 06-04-2013, 03:43 AM Thread Starter
dadada's Avatar
Fuel sump question?
Do they make a fuel sump kit that will run the fuel line directly to the stock fuel pump?Without having to run into a pre-filter,Air dog or Fass.Or can you just tee into the stock fuel line?Please enlighten me.Im having 1/4 tank issues bad and I wanna go that route,if I can.
2001 F-250 4X4 SCSB 7.3 Auto X Codes w/ 2" Hanger/Shackle Drop Kit-38R w/Turbomaster,AFE, T500, Regulated Return, 6.0 Tranny Cooler, JWVB, 4"Exhaust, Hydra w/ Gearhead, PHP, and Powerstruck tunes, Powerstruck 180/100's Live Tuned by Powerstruck and then some!
dadada is offline
post #2 of 32 (permalink) Old 06-04-2013, 04:00 AM
the stryker god
Re: Fuel sump question?
Pumps are expensive, pre pump filtration is not. Most have a -8 or -10 fittin so just go get some parker push lock fittings and I'm sure you can rig it to a stock pump
bruce51d is offline
post #3 of 32 (permalink) Old 06-04-2013, 05:10 AM Thread Starter
dadada's Avatar
If anyone out there has done this,fill me in.Im curious.
dadada is offline
post #4 of 32 (permalink) Old 06-04-2013, 05:14 AM
Administrator
Zmann's Avatar
there is no reason you can't sump an OEM pump IMHO
but as mentioned u loose your screen so your pump is vulnerable
also think about a inline shut off valve for service work
there is also no real reason you can't fix your stock pick up and solve your 1/4 tank issue
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 32 (permalink) Old 06-04-2013, 05:43 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I kicked around a sump... I kicked it to the curb.
Running a 5/8" pick up now and love it... Hope to be able to share one of these days...
Joe
CSIPSD is offline
post #6 of 32 (permalink) Old 06-04-2013, 08:36 PM Thread Starter
dadada's Avatar
I'm gonna run a sump and build my own pre filter kit.Just gotta round up the parts to build it.I'll probably use Beans sump kit.
dadada is offline
post #7 of 32 (permalink) Old 06-05-2013, 12:14 AM
SledDogg's Avatar
All you need is a Baldwin filter head thats like $50. You can buy a sump kit for only about 35 40 dollars more than what its going to cost you to buy all the parts. And you're still going to have to pay shipping fees or drive around a pic of all of them up.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #8 of 32 (permalink) Old 06-05-2013, 01:11 AM Thread Starter
dadada's Avatar
They sell filter heads all day long on eBay for cheap and I'm not gonna use a Baldwin filter.Parts are cheap at the local auto parts store minus the sump.
dadada is offline
post #9 of 32 (permalink) Old 06-05-2013, 01:31 AM
CSIPSD's Avatar
Hang off on cutting a hole in the bottom of your tank... Seriously. Just wait a month or two...
You will thank me later.
Joe
CSIPSD is offline
post #10 of 32 (permalink) Old 06-05-2013, 02:09 AM
SledDogg's Avatar
And why wouldn't you use Baldwin filter heads? 90% of diy guys use them as well as many kits. Snd they have the best.filters for the money.
SledDogg is offline
