Walbro big enough for 250/100? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-03-2013, 05:02 AM Thread Starter
powerstrokin44's Avatar
I just got done putting all the stuff in my signature on. But I need a better fuel pump before I get it to WOT. So I was thinking the bolt on walbro from Full Force and get a in tank mod and see how long I can get out of it. Is it enough fuel for my 250/100's?
2000 F-250 Stroker, Cale's tunes, modded H2E, Full Force 250/100, Built tranny from John Richmond, Precision converter, Manley rods, Mahle pistons, clevite bearings, girdle, sbi valves, a1000, Comp springs, Smith bros pushrods, billet plenums, DI RR.
powerstrokin44 is offline
post #2 of 10 (permalink) Old 06-03-2013, 05:57 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Walbro big enough for 250/100?
Sure... Until it quits.
I used to recommend the Walbro pumps, but just replaced the 3 in as many years. Sticking with the stock pumps from now on.
Joe
CSIPSD is offline
post #3 of 10 (permalink) Old 06-03-2013, 03:16 PM Thread Starter
I was thinking about doing dual stockers. Where's the cheapest place to get the pump if I decide to go that route?
post #4 of 10 (permalink) Old 06-03-2013, 03:29 PM
CSIPSD's Avatar
Riffraff Diesel: Bosch Electric Fuel Pump
Joe
CSIPSD is offline
post #5 of 10 (permalink) Old 06-04-2013, 01:42 AM
mtray's Avatar
how exactly do you plumb the dual stockers together, obviously one feeds the other and will have one line inbetween them right? but electrical wise do you wire the second pump into the others wiring harness or do you have separate wiring for each one?
2000 Ford F250 7.3 4x4. MODS: Beans Tunes, Jegs 4" exhaust, S&B intake, boost fooler, USA poted housing, RR billet wheel for ported housing, HFO, glowshifts 3-in-1 gauge pyro, boost, trans. AIH delete, bellowed uppipes, Sinister Diesel coolant filter.
mtray is offline
post #6 of 10 (permalink) Old 06-04-2013, 01:49 AM
CSIPSD's Avatar
I have mine running side by side.
5/8" pick up to filter head, two suction lines, one for each pump, then feeding the final filter and a 5/8" to the motor.
Only thing the factory wiring is doing is hitting a relay. The pumps are run off there own power supply from the battery.
Joe
CSIPSD is offline
post #7 of 10 (permalink) Old 06-04-2013, 02:35 AM
mtray's Avatar
gotcha that would actually work better than one feeding the other, didnt know if the factory wiring included the power supply, thats what i was confused about
thanks CSIPSD
mtray is offline
post #8 of 10 (permalink) Old 06-04-2013, 05:13 AM Thread Starter
Are you running check valves so they do not back feed?
post #9 of 10 (permalink) Old 06-04-2013, 05:41 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
a map with parts list..its the last post in this thread
Maintain's Install Info..lots of good stuff here!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Ron's power stroke is offline
post #10 of 10 (permalink) Old 06-04-2013, 05:42 AM
CSIPSD's Avatar
Yes.
Joe
CSIPSD is offline
