Lets talk turbos - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 44 (permalink) Old 06-02-2013, 02:36 PM Thread Starter
Lets talk turbos
OK being as I can't leave anything well enough alone I'm planning my next upgrades. I want to do a t4 or t4i turbo. My up pipes are leaking and the .84 housing on my stocker isn't cutting it. I would rather spend the 700$ it would take to fix those issues on something that will provide room for future growth.
I realize that there will be other costs associated with doing this beyond the 700$ t4 mount, such as down pipe, intake spyder and so forth. My real questions revolve around which turbo.
Requirements are:
1) must be rebuildable. No chra's that require 2/3 the cost of original turbo.
2) support 450 horse for now
3) emphasis on towing, secondary on daily driver.
4) good drive pressure ratio.
Opinions and why? Thanks gentleman.
P.s. I keep hearing about nltd's mount kit but can't find any info on it.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #2 of 44 (permalink) Old 06-02-2013, 02:41 PM
the stryker god
Re: Lets talk turbos
Pm thug like he can set you straight on nltd's stuff. I'm running a modded h2e on carson's mount that I got used for 1500 and I'm tickled to death with it. Deals are out there all the time
bruce51d is offline
post #3 of 44 (permalink) Old 06-02-2013, 03:46 PM Thread Starter
Ya just missed a good deal in classifieds on an h2e setup. If you had to buy new is that the setup you'd go with?
02 F350 CC DRW 4X4.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
post #4 of 44 (permalink) Old 06-02-2013, 04:17 PM
the stryker god
Have you considered a super duty 66? Basically a journal bearing 38r that's easily rebuildable
bruce51d is offline
post #5 of 44 (permalink) Old 06-02-2013, 05:28 PM Thread Starter
Is that a 38 chra with 38r backplate, compressor housing and wheel?
02 F350 CC DRW 4X4.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
post #6 of 44 (permalink) Old 06-02-2013, 05:38 PM
the stryker god
Yeah that's pretty much what I said
bruce51d is offline
post #7 of 44 (permalink) Old 06-02-2013, 06:30 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
IMHO there is no tougher turbo, not more easily modified turbo then the H2E...
I've run the PISS out of mine for 150k, and its still as good as the day I installed it.
Joe
CSIPSD is offline
post #8 of 44 (permalink) Old 06-02-2013, 07:34 PM
I have the HFSB(newer version of the GQSSB) and i really like it. It to is a T4i mount and is working great with my set-up. Tows extremely well and also works for a daily driver.
Curtsey
Early 99 Crew Cab,LB , 4" magna-flow exhaust, S&B Intake, FASS Pump, HRX, Regulated Return, Riff Raff Billet Plenums, ARP Studs, 910 springs, Chromoly Push rods, OBA, Carson Stuaffer t4 mount and a Borg warner s64.5 sxe Turbo, PIS 175/80's, T-500, ISSPRO EV2 Gauges, BTS Trans!
cjfarm11 is offline
post #9 of 44 (permalink) Old 06-03-2013, 01:35 AM
yzstroker11's Avatar
I just did a sd66 And is a lil lagy But with stock sticks Cant wait for some hybrids, see the true colors of 66mm's
yzstroker11 is offline
post #10 of 44 (permalink) Old 06-03-2013, 03:50 AM
SledDogg's Avatar
No Limit Tuning Design
Jonathon can turn your stock turbo into a 66mm beast. Since you have billet Wicked Wheel II cost should be $1050. It can be modified enough to support 600hp.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
