Waste Gate actuator on TN drop in?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 10-09-2007, 05:46 PM Thread Starter
thetonka's Avatar
There has been some talk about waste gate actuators lately and discussions about the BHA and the TM. Just wondering how the actuator that comes with the TN drop in works? Is it a POS or does it work well. I am not getting the boost I would like, but I don't know at this time whether its because of leaks, actuator, or a crappy guage .
So for the TN turbos is it worth it/needed to replace the actuator with a TM or BHA?
2001 F350 CC LB 4X4
TN, AIS, DP 80hp, ITP boost elim, Magnaflow 4".
Tows the big white hauler.
When life gives you Lemons, throw them at the stupid people.
thetonka is offline
post #2 of 19 (permalink) Old 10-09-2007, 05:53 PM
HP Junky
Re: Waste Gate actuator on TN drop in??
What kind of boost are you seeing? The most I ever saw with stock injetors was 27-28psi.
RockinJW is offline
post #3 of 19 (permalink) Old 10-09-2007, 07:19 PM Thread Starter
thetonka's Avatar
Mine stays below 20 pretty much all the time. Like I said I think I have an exhaust leak(even though they were replaced in Dec '06), possible boost leaks(gonna fix when I put in the 6L CAC), and I have NO confidence in the guage. The shop that did my exhaust ran it around on a scanner and it read up to 28 psi when the guage was reading 18 psi. POS BullyDog gauge, gotta get me a new one.
2001 F350 CC LB 4X4
thetonka is offline
post #4 of 19 (permalink) Old 10-09-2007, 07:34 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
The TN wastegate is larger then stock and ajustable, I see no need to replace it.
Joe
CSIPSD is offline
post #5 of 19 (permalink) Old 10-09-2007, 09:49 PM
Corona Killa
THEDIESELMAN's Avatar
That is great I have been thinking the same thing if the TN WG is any good because my TN BB unit was shipped out today hope to have it on this weekend if I'm not busy.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #6 of 19 (permalink) Old 10-10-2007, 12:25 AM
<<<<< Next Generation
boggerr's Avatar
20lbs must be the leaks or gauge. I was hitting 25-27 on 4 bad stock injectors.
N.E. Terminator Tech
2000 F350 Lariat CC 4x4 LWB Auto
DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans.
boggerr is offline
post #7 of 19 (permalink) Old 10-10-2007, 03:10 PM Thread Starter
thetonka's Avatar
Yup. I know my injectors are worn out, but it still smokes far more than I would expect, runs hotter, and shows little boost. Its still pulls hard and on my last trip to Palmdale I got 18 mpg.
2001 F350 CC LB 4X4
thetonka is offline
post #8 of 19 (permalink) Old 10-10-2007, 06:44 PM
Braaaaaaaaaaaap
Dysfunctional's Avatar
I've had four TN turbo's on mine... I have never touched the waste gate actuator on any of them. I've seen 30psi out of all of them.
'00 F350 CC LB 4wd 7.3L with stuff, haulin' a 40' trailer with toys
Dysfunctional is offline
post #9 of 19 (permalink) Old 10-10-2007, 09:00 PM Thread Starter
thetonka's Avatar
So your saying something is wrong with my truck?
2001 F350 CC LB 4X4
thetonka is offline
post #10 of 19 (permalink) Old 10-10-2007, 09:31 PM
Braaaaaaaaaaaap
well... it is a ford right...
