01 excursion needs injectors and I need anwsers - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-02-2013, 12:33 AM Thread Starter
powersmoke6.0
silverstroker6.0's Avatar
I have an 01 excursion and the injectors are going out its just got a little super chip micro tuner on a tow tune.. I was wondering what brand and how much bigger to go without moding anything else this is a Daily driver and used to pull boat.
silverstroker6.0 is offline
post #2 of 10 (permalink) Old 06-02-2013, 01:19 AM
the stryker god
Re: 01 excursion needs injectors and I need anwsers
If you don't want to upgrade tunes you can only get stock. But if you don't want to upgrade turbo I wouldn't go over a stage 1 160cc single shot injector. Swamps, full force, unlimited, rosewood and performance injection systems all make a good injector
bruce51d is offline
post #3 of 10 (permalink) Old 06-02-2013, 03:22 AM Thread Starter
powersmoke6.0
I wouldn't mind to upgrade tunes but I'm on a budget
post #4 of 10 (permalink) Old 06-02-2013, 03:26 AM
the stryker god
buy swamps injectors and get tunes for free but even stock injectors can over drive a stock turbo
bruce51d is offline
post #5 of 10 (permalink) Old 06-02-2013, 04:34 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Look up AC injectors... Nice bump, works nice with the stock turbo (I would suggest RiffRaffs new compressor wheel) and gets good mileage.
You will need to upgrade to a TS or Hydra chip and run some single shot tunes, but overall, there is no better injector for a mild modded rig.
AC codes...
Joe
CSIPSD is offline
post #6 of 10 (permalink) Old 06-03-2013, 06:42 PM
International Coal Roller
jbwaldrop88's Avatar
Big question is how big is your budget? Injectors after cores are$1500, then $300-500 for chip, but imo go with single shots and a hydra.
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #7 of 10 (permalink) Old 06-09-2013, 10:19 PM
SledDogg's Avatar
94-03 Stage One Single Shot 160CC
When you buy injectors from Full ForceForce you can get Matt Robinson Gearhead t Automotive tune on a 6pos chip for 400 dollars extra.
Definitely recommend spending the $200 from riff raff diesel for the billet the presser wheel.
I would also recommend getting the FrX fuel crossover/pressure kit from Riff Raff $189
So $2,000 gets a bad ass pkg.
You will need to upgrade the transmission soon, better torque converter and valve body at a minimum.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #8 of 10 (permalink) Old 06-11-2013, 12:24 AM
Old Yeller, REBORN
kilapapipa's Avatar
Or pull your injectors and send them to Rosewood for a rebuild, $500-$1200. I just sent a set in and it was $600. Made a world of diff. for a stock 01'.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #9 of 10 (permalink) Old 06-11-2013, 12:27 AM
97250HD's Avatar
I would recommend Rosewood to for a budget also. Great guy to deal with and I got mine back in about 7-8 days.
97 F250 eclb. 265k
- Fresh engine. d60. zf5. Some other stuff...
E99 f550 213k
- starts every morning...
97250HD is offline
post #10 of 10 (permalink) Old 06-11-2013, 01:24 AM
i got my 238cc/100 hybrids from rosewood also. i got the premium build, and sent them out on monday and got them tuesday of the following week. great guy to deal with also. they only cost $1595 well the shipping was an extra 25 .
ibleeddiesel is offline
