t500 with stock injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-01-2013, 09:28 AM Thread Starter
hey guys im new to this site, i just recently have to replace my stock hpop. decided to go with the t500 , plan on throwing it on, heard a lot of good reviews.. am i going to notice any performance gains or power quality being that i have stock injectors?
mxdalton21 is offline
post #2 of 8 (permalink) Old 06-01-2013, 09:34 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: t500 with stock injectors
going to depend on how bad your stocker was but yes..you should see a little more power and little less black smoke...
Ron's power stroke is offline
post #3 of 8 (permalink) Old 06-01-2013, 09:38 AM Thread Starter
i do also have a DP setup in the truck, idk if that makes a difference as far as the gains i might recieve?
post #4 of 8 (permalink) Old 06-01-2013, 09:44 AM
wont make a difference..you will only feel the gains of better oil PSI feeding the injectors...if you data log icp and duty cycle he might be able to pull a little more out of it...
post #5 of 8 (permalink) Old 06-01-2013, 09:47 AM Thread Starter
ok thanks for the heads up. also i was wondering with the t500, some people say theyre rated up to stage 2 injectors and also a few hybrids. whats yalls input on this? i was thinking about getting a set of stage 1s or 2s i just cant decide what would be best for me
post #6 of 8 (permalink) Old 06-01-2013, 09:56 AM
you will be fine with the T500... base your injectors on the HP your looking for as well as what your doing with the truck... just a daily driver or is it towing all the time.. not sure whats done to your truck but you will want a full regulated return,you will want gauges and you may need to step up on the turbo or modify your stock turbo..
when looking for injectors look at how many cc's and nozzle size....not all builders use the same scale such as stage 1 or stage 2
post #7 of 8 (permalink) Old 06-01-2013, 01:57 PM
SledDogg's Avatar
Get 160cc with 100% nozzles if you get sticks. Not for more power but necause they can be tuned for far better egt control over stock nozzles.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #8 of 8 (permalink) Old 06-01-2013, 09:04 PM
If your stock HPOP is weak, you will definitely notice a difference.
A T500 can handle stage 2's just fine.
