gauges ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 05-31-2013, 03:46 PM Thread Starter
gauges ?
What's the better bang for the buck ...have been looking by time you put 3 gauges in the truck you can put a dig display
redpowerstroke is offline
post #2 of 22 (permalink) Old 05-31-2013, 03:54 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: gauges ?
Isspro EV2. Why would you want to cheap out on gauges?
Joe
CSIPSD is offline
post #3 of 22 (permalink) Old 05-31-2013, 03:58 PM Thread Starter
Re: gauges ?
Not wanting to cheap out but the display will show you more info than just two or three gauges..
post #4 of 22 (permalink) Old 05-31-2013, 04:30 PM
Re: gauges ?
Its a matter of personnel preference. I prefer my insight CTS because of the ability to monitor things such as IPR, pulsewidth, and back pressure when ever I want. But don't be fooled by the intro price of a digital monitor. By the time you add in the extra sensors required your over 700$. A digital monitor is also not as reliable as a set of isspro gauges. Like I said personel preference.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #5 of 22 (permalink) Old 05-31-2013, 08:40 PM
Re: gauges ?
I have run both analog and digital gauges. I am currently running a digital gauge and would not even think of going back to analog. Analog gauges are extremely limited and serve only the purpose of watching 1 parameter. Most digital gauges will watch at least 20 different parameters and read/clear codes.
A unit like our Infinity has the ability to watch hundreds of parameters, read/clear codes, datalog, run diagnostic tests, tune, play media, and more.
post #6 of 22 (permalink) Old 06-01-2013, 01:44 AM
CSIPSD's Avatar
Re: gauges ?
I prefer gauges over an all in one display. All in one's are easy to steal, easy to break, rely on the PCM for there communication and are harder to read at a glance.
I don't even have to read my gauges to know where they are at. Just out of the corner of my eye I can tell what EGT's, Trans and other temps or pressures are.
There is a reason why even airplanes still use an analog display.
Joe
CSIPSD is offline
post #7 of 22 (permalink) Old 06-01-2013, 02:42 AM
International Coal Roller
jbwaldrop88's Avatar
Re: gauges ?
Fwiw I vote isspro
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #8 of 22 (permalink) Old 06-01-2013, 04:45 AM Thread Starter
Re: gauges ?
Thanks... I think I am going gauges
post #9 of 22 (permalink) Old 06-01-2013, 04:49 AM
SledDogg's Avatar
Re: gauges ?
No Glow Shift gauges.......ISSO only.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #10 of 22 (permalink) Old 06-01-2013, 05:21 AM Thread Starter
Re: gauges ?
Are the isspro better than autometer
