Traction problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 05-31-2013, 03:34 AM Thread Starter
Traction problems
hey guys having trouble getting my new found power to the ground
was wondering if anyone had the same problem and what they did I have traction bars that are homemade and Ive tried lowering the air pressure in my tires but im still spinning tires at 80mph. I would like to be able to at least give my truck a full throttle run and full boost pressure
thanks
2000 F250 SCSB 6-speed, stage 3 clutch, lifted 4'' with 37's, 5er, 4'' turbo back, 6637 intake, STAGE II Rosewood singles, PHP Phoenix chip, 38R, 910"s shimed, Traction Bars.
05/12_288.64 RWHP. 575.04 FT-LBS-TQ
JUST DYNOED! 411 HP 794 FT-LBS-TQ
RLSCOAL is offline
post #2 of 15 (permalink) Old 05-31-2013, 04:18 AM
Derkperk's Avatar
Re: Traction problems
Sounds like time for some new rubber.
05 Intl F250 CCSB FX4 Lariat
6.0, studded, updated, modified
Derkperk is offline
post #3 of 15 (permalink) Old 05-31-2013, 04:30 AM
jaybuller's Avatar
I have a hard time believeing you can spin tires at 80 mph with anything less than 600 hp on dry pavent especially with 37s
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #4 of 15 (permalink) Old 05-31-2013, 05:29 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Agreed... With a 400hp truck, its not happening.
Joe
CSIPSD is offline
post #5 of 15 (permalink) Old 05-31-2013, 05:37 AM
Village Idiot
southmike's Avatar
Eaton tru trac..maybe..
Hope it is tire not your clutch spinning...lol reminds me of a you tube video and a yello corevette doing a burnout...priceless
southmike is offline
post #6 of 15 (permalink) Old 05-31-2013, 12:15 PM
Cv0lv0g0's Avatar
He's wheels maybe chirping and 80 when he drops the clutch. Not spinning just chirping.
It was 5:30 in the morning someone needed help. I was to lazy to put the chains on. I ended up needed the help.
Cv0lv0g0 is offline
post #7 of 15 (permalink) Old 05-31-2013, 01:54 PM
Interested what this new set up you have is...that's a heavy truck to spin at that speed
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #8 of 15 (permalink) Old 06-01-2013, 08:53 AM
I could see spinning them on wet pavement at 65, my old OBS 250 would do that with 300hp and the 235/75/16's and 355 gears once the boost built is would start sliding sideways down the freeway.
Big Bird is offline
post #9 of 15 (permalink) Old 06-01-2013, 05:36 PM Thread Starter
mods are in sig and I have a open diff with military 37's at 45psi if your not familiar with the military tires they have very little in contact with the ground. I think just the drive tire is spinning cause it doesnt spin in 4wd and the diff is open. also It will spin in lower gears if I hit bumps in the road. my traction bars are not set up right i just put them in one night before a pull been meaning to change them. 80mph is just a guess the tires have thrown off the speedo the chip was supposed to correct it but it didn't. and on wet pavement I can get the truck to go sideways on the highway but its starting to get anoying cause I want to go fast! not ruling out the clutch slipping, do you guys know of a way to check it with out pulling the trans?
RLSCOAL is offline
post #10 of 15 (permalink) Old 06-01-2013, 05:38 PM Thread Starter
The truck is empty all the time now that I live in the city so there is no weight in the bed the truck is around 7500lbs now idk if that helps.
RLSCOAL is offline
