boost fooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 05-31-2013, 12:31 AM Thread Starter
boost fooler
is it worth it? whats its purpose?
7.3strokin' is offline
post #2 of 34 (permalink) Old 05-31-2013, 01:15 AM
International Coal Roller
jbwaldrop88's Avatar
Re: boost fooler
Depends on what you are expecting out of it, its not gonna give you a ton of power, personally id say its a waste of money, just save and get a set of gauges and a chip, especially with a chip its kinda pointless since most tuners tune around the overboost anyways. The way I see it is it will fool the computer into not defueling, however you will have extra boost and not extra fuel so I see a lean fuel situation.
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
post #3 of 34 (permalink) Old 05-31-2013, 02:02 AM
Joeyd61's Avatar
Re: boost fooler
I am curious, how much boost is bad for the map??
2003 F250 7.3 PSD Lariat,fresh forged rod motor,Full Force 300/200 Hybrid injectors,Terminator Dual HPOP,BW S468 turbo w/race cover,Isspro Guages,BTS Trans,XRF front end,Red Head steering box, Yukon 4.56gears,6" BDS lift,AD 150 w/sump,Walbro pump,SD Regulated Return,DP tuner Live Tuned,armed with Infinity and on & on & on
Joeyd61 is offline
post #4 of 34 (permalink) Old 05-31-2013, 03:09 PM
jtgf250's Avatar
Re: boost fooler
Agree that just get the chip and gauges to be safe. Also, may not get extra fuel but you keep getting fuel versus none.
But if you have to ask what it is you probably dont need it.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #5 of 34 (permalink) Old 05-31-2013, 04:23 PM
Re: boost fooler
You will still get an ses light if you make boost pressure over 25psi even if your tuner did away with the defuel program. 50$ was worth it to me to not have a light come on every time I get in the throttle hard.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #6 of 34 (permalink) Old 06-01-2013, 02:47 AM
Re: boost fooler
I've seen a truck with a manual wastegate cranked all the way shut and a PHP phoenix chip hit 30 psi and not once threw a cel, however said truck throw an overboost with a superchips before he got the phoenix. My truck has some canned tune on it from the previous owner, don't know which one so I try to take it easy but mine will hit 26 before it pushes open the waste gate, and no cel.
post #7 of 34 (permalink) Old 06-01-2013, 03:30 AM
SledDogg's Avatar
Re: boost fooler
I have stage 1's sticks and Matt Robinson Gearhead tunes and never throw a cel hitting 31psi.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #8 of 34 (permalink) Old 06-01-2013, 04:28 AM
jaybuller's Avatar
Re: boost fooler
Thats odd I have his tunes as welll and set ses every time I hit 30 lbs
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #9 of 34 (permalink) Old 06-01-2013, 04:45 AM
SledDogg's Avatar
Re: boost fooler
Not sure if it matters but I had a new ICP, IPR, HPOP, & fuel pump also installed when I added sticks and tunes.
SledDogg is offline
post #10 of 34 (permalink) Old 06-01-2013, 06:07 PM
jtgf250's Avatar
Re: boost fooler
Running a PHP Hydra and I dont through a light.
jtgf250 is offline
