Engine Rebuild... What do I need to know - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 01-05-2009, 02:03 AM Thread Starter
The Fireman
big_stroker's Avatar
I am pulling and rebuilding me engine since I got coolant in my oil. Not sure what the problem is yet since its not tore down but i will soon enough.
Figuring that its just a pin hole in the block can i just sleeve it?
Also wonder what aftermarket stuff should i go with on the rebuild. I know im going to put in studs but didnt know about springs and stuff like that.
I plan on doing the DIY stage 3 injector kit sometime if not when i do the rebuild and a 38r soon after.
Should i worry about roads and stuff?
I'm looking to spend about 4 - 5 thousand on the rebuild.
big_stroker is offline
post #2 of 26 (permalink) Old 01-05-2009, 02:04 AM
Re: Engine Rebuild... What do I need to know
Billett rods !!
speediseverything is offline
post #3 of 26 (permalink) Old 01-05-2009, 02:08 AM Thread Starter
The Fireman
Originally Posted by speediseverything View Post
Billett rods !!
What kind and how much do these run... i was thinking about that but i think they are a little out of my price range if im not mistaken and i do have forged rods now
post #4 of 26 (permalink) Old 01-05-2009, 02:44 AM
Plays with Motors
Machinist's Avatar
I would not be rebuilding the motor just because there's chocolate milk in the pan - there's a few common causes of this, none of which require a rebuild and all will save you thousands of dollars...
Blown head gasket
Leak under timing cover
Oil cooler
How many miles on the motor?
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #5 of 26 (permalink) Old 01-05-2009, 02:51 AM Thread Starter
The Fireman
Blown head gasket
Oil cooler
Well i have checked the compression so i dont think its a head gasket all checked out and i was told if it was oil cooler there would be oil in the coolant not coolant in the oil
explane more about the Leak under timing cover?
and there is 210k on the engine
post #6 of 26 (permalink) Old 01-05-2009, 03:01 AM
Plays with Motors
Machinist's Avatar
It can mix both directions in the oil cooler - and a compression test is not going to show a head gasket that is bypassing coolant.
There is an oil passage at the top corner of the block under the timing cover that I have seen leak to the coolant area of the cover. If the timing cover is removed you may see some dark discoloration in that area if it was the cause.
2011 335i M-Sport
post #7 of 26 (permalink) Old 01-05-2009, 04:05 AM
Busy Busy
Marty's Avatar
have you checked the oil cooler?
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #8 of 26 (permalink) Old 01-05-2009, 05:16 AM
Pulling sled for hire
ParkerFly's Avatar
If you're going to Stage 3 hybrids and have the right supporting mods you will push 500 hp. You'll either need rods or some conservative tuning to be reliable. Rods won't be cheap, plus the block likes to wiggle around once you get to 500, so you might be better off with Stage 2's and not have to worry with everything else.
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #9 of 26 (permalink) Old 01-05-2009, 06:09 AM
Busy Busy
Marty's Avatar
He said the block likes to wiggle around.
Elkton, Maryland
Marty is offline
post #10 of 26 (permalink) Old 01-05-2009, 10:18 AM
Don't EFN worry about it
Aljay's Avatar
Fill that bish then girdle it then see how bad she wiggles.
Tuned by T Wildman
Aljay is offline
