Another Spring question... ASAP Please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 10-09-2007, 04:08 AM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Still looking for the valve springs, had the guys looking up the 910 part number and its not coming up as a Powerstroke specific spring but has the correct size...
Can anyone pull a correct part number or conferm this is what you all are using.
Thanks!
FYI, Motor came out today, going to send the wife down tomarrow to take some pic's if she can... She had knee surgery on thursday so asking for something... well... it might be a little tricky...
Joe
CSIPSD is offline
post #2 of 15 (permalink) Old 10-09-2007, 04:17 AM
<- Sums it up
strokin_early_99's Avatar
Re: Another Spring question... ASAP Please
CCA-910-16
Look here: http://store.summitracing.com/partdetail.asp?autofilter=1&part=CCA%2D910%2D16&N= 700+0&autoview=sku
Summit will price match. Use this site for the price to match as they have the best price anywhere: http://www.hallspeedshop.com/valve-springs-p-19514.html
Not specific for powerstroke. Call Bean if you need a pro to verify.
Keep Strokin'
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #3 of 15 (permalink) Old 10-09-2007, 04:19 AM
They are not PowerStroke specific springs. They aren't specific to any engine in the respect they are bolt in type direct replacement. They work fine in a 7.3 however. I ordered Comp PN#26120-16 springs
69W900A is offline
post #4 of 15 (permalink) Old 10-09-2007, 04:26 AM
<- Sums it up
If so, then you also ordered replacement retainers also, correct? The locks will work but the spring you ordered a larger in diameter spring than stock or the 910's, correct?
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #5 of 15 (permalink) Old 10-09-2007, 04:29 AM Thread Starter
CSIPSD's Avatar
Thanks, I thought they had the right part number...
They are ordering from Comp Specialty's here in the NW... Going on my account...
Joe
CSIPSD is offline
post #6 of 15 (permalink) Old 10-09-2007, 04:30 AM
Yes, I bought all new stuff. Retainers, seats and locks.
69W900A is offline
post #7 of 15 (permalink) Old 10-09-2007, 04:53 AM
Needs more hours per day
jtharvey's Avatar
How much $$$ do seats and locks typically run?
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #8 of 15 (permalink) Old 10-09-2007, 05:01 AM Thread Starter
CSIPSD's Avatar
I have heard the total is about $350 for that set up, where as the 910's are about $90...
I am counting my penneys at this point so the $100 bill looks real good...
Joe
CSIPSD is offline
post #9 of 15 (permalink) Old 10-09-2007, 05:07 AM
I think I payed about 215 for springs, seats, locks and retainers. I bought them from Comp Specailties in Auburn, Summit is a bit higher.
Anything is better than stock.
69W900A is offline
post #10 of 15 (permalink) Old 10-09-2007, 06:03 AM
Anything from Comp is more than you can get it from Summit. The prices they sell to the dealers is about the same or a touch more than Summit sells to the public. Then the dealer marks it up etc. Ideally who ever is installing them should be checking each one and shimming to the proper seat pressure. They should be setting them approximatly 10&#37; high to allow for the settlement of new springs.
Remember that pinching pennies is good where it's safe. But don't skimp on parts that are hard to replace down the road or parts that you really need to pay for the quality up front. $100 extra now is well worth the couple thousand saved in repair bills down the road when the valve starts hitting the piston and busts the head off and takes out a piston, cylender, head.
hotwheels is offline
