Ordered a php hydra. Now have a few questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-27-2013, 01:59 PM Thread Starter
Coal Train Diesel
ventryjr's Avatar
Ok so I ordered the chip Thursday am of last week. I ordered with 4 custom tunes. I ordered it to run my new 160cc injectors. Anyways I was reading after ordering that you have to wait 20 seconds after changing tunes. Is this true? Or can I change like my ts? Just let off gas. Change. Wait a few seconds then drive. Any input? Also how long should I expect to wait for the tunes? Thanks.
Sent from my VS930 4G using AutoGuide.Com Free App
01 f350 dually CCLB, 7in lift, 6637 zoodad, 4.5" stacks, Isspro gauges, PHP Hyrda, ww2, industrial injectors 180/40
ventryjr is offline
post #2 of 7 (permalink) Old 05-27-2013, 03:14 PM
jtgf250's Avatar
Re: Ordered a php hydra. Now have a few questions
Unless its different for custom tunes then no. I switch on the fly and just wait for the number to blink, like 2 seconds. Dont have any custom tunes yet but ask jaybuller, hes running custom tunes on his hydra. I've heard it takes a while to get custom tunes from Bill, you'll probably get the hydra in the mail before you get your tunes. It doesnt come loaded, you have to install them once they email them to you I believe.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #3 of 7 (permalink) Old 09-27-2013, 09:02 PM
ju015dd's Avatar
I am still waiting on mine as well. Hope to get them sooon
2000 Ford F250 Powerstroke 4x4 c/c 6speed, 278k on truck and 207k on 96 engine all cylinders blew 400 psi, melling lpop, comp springs shimmed, smith brother push rods, 238/100% Hybrids by Rosewood, 38r/ww2, Strictly Diesel Reg Return, Strictly Diesel post and pre fuel filters, AFE - Straight Piped, Hydra with PHP tunes, Srp 1.1, !
ju015dd is offline
post #4 of 7 (permalink) Old 09-27-2013, 09:13 PM
I have a hydra and I have not had to wait 20 seconds. I usually let off and let it do its thing for a few second and then touch the pedal again.
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #5 of 7 (permalink) Old 09-27-2013, 09:30 PM
jaybuller's Avatar
No waiting, no letting off gas nothing, just switch it. I have custom tunes on mine and it switches just fine. If you heard or read that it takes 20 seconds to load tunes it probably means it takes 20 seconds to load the tune onto the chip itself from your computer, because that's about how long it takes!
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #6 of 7 (permalink) Old 09-28-2013, 01:07 AM
dsberman94's Avatar
What jay buller said. I change with my foot in it about half throttle and uphill with no problems. Just feel a power increase.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #7 of 7 (permalink) Old 09-28-2013, 02:22 PM
Hansel's Avatar
If I switch tunes it's usually when at an idle, but just switch it on the fly. Ive heard no change in the engine when changing the programming it just blinks telling you that your in the new tune.
2001 7.3L CCSRW 4X4 Lariat
Airaid intake
Stock for now
Hansel is offline
