overdive light flashing... pls help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-26-2013, 03:49 AM Thread Starter
yesterday i was messing with my esof relays because i have been having issues with my 4x4 egaging, well i did something and i blew the #16 30amp fuse for the esof. I didnt have one to replace it so i took one out of the #17 ( trailer tow battery charge) spot and put it in the esof spot. i ran out of light outside and i put everything back together. not thinking about it, i drove it to work, on my way home my overdrive light started flashing. its shifts fine and overdrive works like normal, so i put a new fuse in the # 17 spot and it still is flashing. with me driving it without that fuse, will it throw a code, and if so how do i clear it? 2000 f-250, 7.3l, 142000 miles
Nate0458 is offline
post #2 of 12 (permalink) Old 05-26-2013, 04:47 AM
Super Hauler!
Super_Hauler's Avatar
Re: overdive light flashing... pls help
Pull your cables off your batteries and it will reset the computer. If it shows back up pull codes with a scanner.
Super_Hauler is offline
post #3 of 12 (permalink) Old 05-26-2013, 12:41 PM Thread Starter
okay thank you. I will try that
Nate0458 is offline
post #4 of 12 (permalink) Old 05-27-2013, 12:46 PM Thread Starter
okay so i disconnected the battery and no luck.... the light came back on. will any code scanner read this type of code?
Nate0458 is offline
post #5 of 12 (permalink) Old 05-27-2013, 03:53 PM
Super Hauler!
AE or any tuner with a scan gauge. The autozone specials will not.
post #6 of 12 (permalink) Old 05-28-2013, 03:45 AM
SledDogg's Avatar
DON'T DRIVE IT!!!!! several internal trans things could be wrong. Been there.......uh replaced trans. $$$$€ not listening to light. Friend kept.plowing on his one night......new trans for him now also.
And replace your trailer charge fuse....it should be a blue box 20 amp fuse, NOT a 30 amp. Owners manual list everything starting on like page 195.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #7 of 12 (permalink) Old 05-28-2013, 04:12 AM
Super Hauler!
You haven't driven in a lot of water lately have you? check the wires under the truck, there is a harness run along side the trans on the drivers side. Seen a lot of trucks where the wires have frayed and have issues like you're describing. you just replace the harness at the frayed wires and use waterproof heat shrink butt connectors.
post #8 of 12 (permalink) Old 05-28-2013, 02:15 PM Thread Starter
ok, so my buddy has a ae scanner and it said it was a code 0708, transmission range sensor output too high.....
Nate0458 is offline
post #9 of 12 (permalink) Old 05-28-2013, 10:15 PM
Did he clear the code.... And it came right back?
1994 F-700 Cummins 5.9 12v and Arbortech chip body
1999 International 4900 DT466E w/Allison auto, flatbed 60' rear mount altec am855 boom.
2001 F-350 7.3 4x4 reg cab, single shots, BTS trans,
35" toyo mt's on black 18" KMC addicts
2006 F-350 6.0 4x4 cc lariat, 20" stock wheels with toyo at's....waiting for studs and all that.
frashdog is offline
post #10 of 12 (permalink) Old 05-28-2013, 10:26 PM Thread Starter
he cleared it but i havent driven the truck...... i was thinking i should replace the sensor first
Nate0458 is offline
