resistor mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-24-2013, 03:09 PM Thread Starter
Smile resistor mod
hi everyone im trying to get a little more power out of my truck i have heard alot about the resistor mod its goods and bads. after reading alot of reviews i wanna give it a shot till i got my ts chip then i will take it out. i would like to know what the best resistor would be i dont want my idle to be really lopey. i just want more low end power and a little smoke. also if someone good give me directions on how to do this mod i know where the icp sensor is just not sure how to hook it up. thanks all help is aprreciated.
early 99 powerstroke ext cab long bed lariat. auto trans. 2 inch shackle lift. napa air filter mod. sct tuner with custom tunes from innovative
early 99 powerstroke is offline
post #2 of 8 (permalink) Old 05-25-2013, 02:47 AM
dadada's Avatar
Re: resistor mod
No disrespect but I would watch talking about wanting smoke.Guys on here really frown on that subject.They will eat you alive with negative comments.Alot of tuners anymore dont have a smoke tune.Most companies try to make tunes with minimal smoke.Good luck!
2001 F-250 4X4 SCSB 7.3 Auto X Codes w/ 2" Hanger/Shackle Drop Kit-38R w/Turbomaster,AFE, T500, Regulated Return, 6.0 Tranny Cooler, JWVB, 4"Exhaust, Hydra w/ Gearhead, PHP, and Powerstruck tunes, Powerstruck 180/100's Live Tuned by Powerstruck and then some!
dadada is offline
post #3 of 8 (permalink) Old 05-25-2013, 03:49 AM
Re: resistor mod
since your truck is an automatic i would not do it. as soon as you hit the go pedal your truck takes off like you just floored it. the tranny will heat up alot quiker also. it doesent give you anymore power it just feels like it because your throttle response is extremly touchy. it will also make your tranny shift differently. just save your money and get a custom tuned ts chip dont waste your time on this. an as for smoke goes keep it on the track no one likes a kid in a diesel truck goin around town smokin everybody out. it gives us diesel freaks a bad name
ibleeddiesel is offline
post #4 of 8 (permalink) Old 05-25-2013, 03:26 PM
38R turbo's Avatar
Re: resistor mod
High voltage/high frequency Injection Driver Module - Swamps Diesel Performance
I have no experience with the resistor mod. I have the Swamps IDM in the link above. There's is a bit more to it than the resistor mod. It works well for me. The pedal is a bit touchier but not bad. I like it.
2000 F250 CC SB 4x4, 7.3 diesel, 4R100, 4"lift, AIS intake, 38R Turbo, Turbonetics outlet, Swamps 200/30 Hybrids, Swamps tunes, Swamps IDM, 4" MBRP, BTS valvebody, 6.0 cooler, ISSPRO fuel press, boost, egt, trans, water temp, ScanGage, Melling Lpop, FRx, Hutch mod, spin on filter/separator, Bosch pump, DIY 3/8 fuel lines, OCR, HPx, Autoenginuity.
38R turbo is offline
post #5 of 8 (permalink) Old 05-25-2013, 03:47 PM
the stryker god
Re: resistor mod
He's not talk in about the idm mod. Regardless I don't recommended doin the "10k" mod
bruce51d is offline
post #6 of 8 (permalink) Old 05-28-2013, 03:37 PM Thread Starter
Re: resistor mod
ok thanks for the advice i trust you guys so im not going to do the mod. ill just get the ts chip as planned thanks.
post #7 of 8 (permalink) Old 05-28-2013, 04:11 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: resistor mod
10-18k mods are hard on trannys.
Joe
CSIPSD is offline
post #8 of 8 (permalink) Old 05-28-2013, 08:39 PM
Cv0lv0g0's Avatar
Re: resistor mod
It was 5:30 in the morning someone needed help. I was to lazy to put the chains on. I ended up needed the help.
Cv0lv0g0 is offline
