Remove chip help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-24-2013, 01:25 PM Thread Starter
dsberman94's Avatar
Remove chip help
Hey guys. I've been trying to find out how to remove the chip that came in my truck when I bought it. The gauge monitor is a quadzilla monitor and it tells me oil temp boost and trans temp and egt is not hooked up. I would imagine the chip would be the same. It's a six position chip but I've never taken one out or put one in or seen one before so idk how to do this. I have an 02 f250. Any help is appreciated. Thanks
dsberman94 is offline
post #2 of 5 (permalink) Old 05-24-2013, 02:19 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Remove chip help
Might post this in the correct section. The 7.3 Performance section would get you an answer...
Joe
CSIPSD is offline
post #3 of 5 (permalink) Old 05-24-2013, 02:36 PM
ohiopowerstoke's Avatar
http://www.tsperformance.com/Downloa...7.3%20Chip.pdf
03 f250 ccsb with 7.3
mbrp 4 inch strait, ts 6 pos, cold air intake, pillar gauges.
ohiopowerstoke is offline
post #4 of 5 (permalink) Old 05-24-2013, 03:02 PM
Freak'n know it all
gottagofast's Avatar
make sure the keys ore NOT in the ign. or you will very possibly toast your pcm
Look under the dash behind the emergency brake.. you should see a 1/4" wire coming out of a hole in the pcm (silver box with a black plastic cover) give the wire a gentle tug. the chip should come out with it
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #5 of 5 (permalink) Old 05-24-2013, 04:23 PM Thread Starter
dsberman94's Avatar
Should I have the chip set to stock or does it not matter?
