too those with snow performance meth kit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 12-29-2008, 07:08 AM Thread Starter
73stroke99's Avatar
where is the best place to mount the tank and pump...i made a nice bracket for my controller to mount now im stuck on a place to mount the other stuff...i really dont want bed mount b/c snow recammends a solenoid for rear mounted tank and pump to prevent draining i guess..but if i have to mount it there can i get by without the solenoid they are talking about?.....Andy M. I know im a little overdue on installing this system...haha
02 F250 s/c, 6ft bed,6 speed,4x4,148k...work in progress...
~ TS chip
~ Intake by me
~ 5 inch straight piped exhaust
~ 2 inch leveling kit with 35s
To come:
keeping this one modest, fuel system, maybe turbo, new tuning, South bend clutch
SOLD~ 04 F250 6.0 ccsb
SOLD~99.5 f250 scsb,auto, 4x4..modded
73stroke99 is offline
post #2 of 13 (permalink) Old 12-29-2008, 04:46 PM
1999F350's Avatar
Send a message via Yahoo to 1999F350
Re: too those with snow performance meth kit
what size tank are you using? i installed a 4qt tank behind the grill once. per customer request. and the pump also, i cut a round hole in the plastic piece for easy refill. it looked pretty cool looking through the grill and seeing a boost juice tank. jay
1999.5 F350 XLT EXT CAB AUTO 4X4,K&N W/6037, DPF5,HIGH IDLE,80T,80E,120R,140BOOSTFOOLER,PHANTOM2 GAUGES BOOST,TRANS, EGT,CUSTOM 4R100 W/ JWVB,BILLET HARD PARTS,427LINE,RACERX PARTS,BD PAN,6.0 COOLER,DETROIT TRU TRAC,3.73,VAN TURBO W/ATS&HIFLO OUTLET,4" STRAIT PIPE,AFE INTAKE MAN,140V IDM,325/60/20 NITTOS,2.5"LEVELKIT,OPTIMA'S,PIONEER DVD/NAV
1999F350 is offline
post #3 of 13 (permalink) Old 12-29-2008, 08:55 PM Thread Starter
73stroke99's Avatar
i assume a 3 qt its not big....anyone one else have an idea?
~ TS chip
~ Intake by me
To come:
post #4 of 13 (permalink) Old 12-29-2008, 09:36 PM
cota's Avatar
I tapped into my window washer fluid container for the tank and mounted the pump in the wheel well below the tank based on recomendations from snow. Was quick and easy with good flow from the tank to pump.
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #5 of 13 (permalink) Old 12-29-2008, 10:02 PM Thread Starter
73stroke99's Avatar
i got my kit used and im not sure if i could reuse the fitting in my tank to tap into my washerfluid res.
~ TS chip
~ Intake by me
To come:
post #6 of 13 (permalink) Old 12-30-2008, 02:06 AM
moore20017.3's Avatar
You still havent tried that out yet. lol
I had it mounted inside the old AFE intake box, after I finished the turbo I just had a filter mounted directly on turbo. That res and pump was just hanging out in the old AFE box.
The idea of mounting pump below and tapping into the washer res is a great idea, then you will have a one gallon res to work with.
I think you have seen my intake (edit no chit its my avatar sorry), it was going to mount inside there if I would have stayed with it. You will be surprised when you finally run it.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #7 of 13 (permalink) Old 12-30-2008, 02:55 AM Thread Starter
73stroke99's Avatar
yeah i have had alot goin on...my tranny is about to take a chit and im hoping to finish it off with this kit and more fuel....the kit works flawlessly....on the bench lol...i think im gonna try and get the adaptor off the snow res. without breaking and try to mount it on the washer tank. What do i have to do to mount it to my res. Just glue it? also whats involed in removeing the inner fender?
~ TS chip
~ Intake by me
To come:
post #8 of 13 (permalink) Old 12-30-2008, 02:58 AM Thread Starter
73stroke99's Avatar
i have been debating what to do with my trans...6 speed swap or jump on bts nutz if there is enough room to swing from...lol...sorry bts users..brian makes a kicka$$ tranny.
~ TS chip
~ Intake by me
To come:
post #9 of 13 (permalink) Old 12-30-2008, 03:06 AM
cota's Avatar
My kit came with everything to tap the washer tank and I just drilled a 1.5" hole in the fender liner for the tap from the tank to drop though. I'm going to use a plastic blank off like you use to cover one of the holes for your sink. It comes with a rubber gasket and long threaded part just like the stock piece in the kit but will allow me to run a 1/2" tube to feed the pump instead of 1/4" tube.
2000,CC,4x4,auto
cota is offline
post #10 of 13 (permalink) Old 12-30-2008, 03:39 AM Thread Starter
73stroke99's Avatar
do i need to install anything inside of my washer tank if so how the heck am i gonna reach in to do it
~ TS chip
~ Intake by me
To come:
