Modified Hpop and Stock injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 12-29-2008, 03:19 AM Thread Starter
tholt34's Avatar
Ok, i have been trying to decide on what i wanna do. I don't remember the exact numbers but i checked my hpop a while back and i had some low numbers in my higher tunes on my dp tuner. I don't really want bigger injectors, but i was wondering what power u can get from stock injectors and a modified hpop? I don't want a race truck, just a nice daily driver and it be good for towing.
Thanks. Tim
2000 F-250 ext cab 4x4 6 spd. Glowshift gauges(egt, boost, and fuel pressure), PHP tuned, DIY intake. MBRP 5 inch straight exhaust with 6 inch tip
tholt34 is offline
post #2 of 16 (permalink) Old 12-29-2008, 04:48 AM
Village Idiot
southmike's Avatar
Re: Modified Hpop and Stock injectors
you should gain a small amount of hp, but ...
your motor will pull much stronger, faster, and be more consistent.
you may gain a micro bit of mpg , and your injectors wont peter out at the end of a hard long pull...
least that was my findings with the pulse unit
southmike is offline
post #3 of 16 (permalink) Old 12-29-2008, 05:13 AM
HP Junky
I loved my truck with the stock injectors and Terminator pumps. Towed awesome with that set-up, all the torque you need with out the egt's.
I'd highly recommend big oil with stock injectors.
RockinJW is offline
post #4 of 16 (permalink) Old 12-29-2008, 03:55 PM
<-- it's like that
I currently run big oil on stock sticks. HP wise you'll see something in the 350 hp range. Just the big oil alone dropped my drag strip times by 8/10ths of a second.
I'll also concur with RockinJW on the power and EGT's. Towing is great with this setup, and EGT's remain under 1200*F in any setting.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #5 of 16 (permalink) Old 12-30-2008, 12:37 AM Thread Starter
tholt34's Avatar
Thanks for the replies. I think that is what i will do in the future. What is the most you can see out of stage 1 injectors?
tholt34 is offline
post #6 of 16 (permalink) Old 12-30-2008, 01:00 AM
2nd class citizen
1snotrocket's Avatar
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #7 of 16 (permalink) Old 12-30-2008, 08:40 PM
Big oil with stock sticks... do you need any special tune to take advantage of the big oil?
01 F350 CCLB SRW
tubular031 is offline
post #8 of 16 (permalink) Old 12-30-2008, 09:14 PM
<----Colin Banks
mattymx's Avatar
You should have a chip that has tuning for big oil. YOu will get the most out of it that way.
mattymx is offline
post #9 of 16 (permalink) Old 12-30-2008, 09:15 PM
What he said.
TerminatorEngineering is offline
post #10 of 16 (permalink) Old 12-30-2008, 09:20 PM
What is better for towing
Big oil with stock injectors and a stock turbo
or
Stock oil, stock turbo and stage 1 single shot injectors
both would be running tonys tunes. It looks like stage 1s are about the same price as the gen3 big oil.
01 F350 CCLB SRW
