right walbro pump?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-21-2013, 10:05 PM Thread Starter
7.3_geek_124's Avatar
right walbro pump??
i recently bought a walbro GSL392 for my 99 superdtuy and the inlet seems like it would fit but the outlet has a larger female end then the stock male end.. has anyone experienced this problem or did i not order the right one?
7.3_geek_124 is offline
post #2 of 10 (permalink) Old 05-23-2013, 12:17 AM Thread Starter
Re: right walbro pump??
bump.. no has had this problem??
post #3 of 10 (permalink) Old 05-23-2013, 12:25 AM
the stryker god
i know a lot of people use that pump, i actually run 2, but idk how many are runnin them with stock lines
bruce51d is offline
post #4 of 10 (permalink) Old 05-23-2013, 12:50 AM Thread Starter
where did you pick up your aftermarket lines from? and was it difficult to install?
post #5 of 10 (permalink) Old 05-23-2013, 01:43 AM
dadada's Avatar
Yes,you ordered the right pump.Its been awhile since Ive installed mine.The end toward the front of the truck will hook right up without any modifications.The factory rubber fuel line on the other end isnt big enough.So you have to pull that line off and go to auto parts store and buy I think 3/8" fuel line,about 10" of line.Make sure you buy fuel injection line and not regular fuel line because of the pressure.Also install hose clamps to keep the line on.Im not 100% on the 3/8" line but if you bought the install kit with the pump,the instructions will tell you what size the barbed fitting is.You have to run a regulator with that pump or you will have issues with way too much fuel pressure.You cannot just run that pump without being able to turn fuel pressure down.
2001 F-250 4X4 SCSB 7.3 Auto X Codes w/ 2" Hanger/Shackle Drop Kit-38R w/Turbomaster,AFE, T500, Regulated Return, 6.0 Tranny Cooler, JWVB, 4"Exhaust, Hydra w/ Gearhead, PHP, and Powerstruck tunes, Powerstruck 180/100's Live Tuned by Powerstruck and then some!
dadada is offline
post #6 of 10 (permalink) Old 05-23-2013, 04:09 PM
Old Yeller, REBORN
kilapapipa's Avatar
Yes, it is the right pump. I have an Air Dog so the rear of my pump needed the following fittings. Been a while so I can't remember what all I did. Here is a thread with some fittings and a picture of mine installed.
? re: Walbro 392 install - PowerStrokeNation : Ford Powerstroke Diesel Forum
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #7 of 10 (permalink) Old 05-23-2013, 05:11 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Just lost my third Walbro in 4 years... As cheap as they are, I'm growing tired of replacing them.
Going to remove it and just run two stockers again, my factory pump with 200k on it is still in there working, just cant maintain the pressure.
Joe
CSIPSD is offline
post #8 of 10 (permalink) Old 05-23-2013, 07:22 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
the Walbro pump is not rated for diesel and will not be covered under warranty ..when i bought my fuelab pump i asked the seller of the Walbro pump this very question,
Ron's power stroke is offline
post #9 of 10 (permalink) Old 05-23-2013, 07:26 PM
CSIPSD's Avatar
Originally Posted by Ron's power stroke View Post
the Walbro pump is not rated for diesel..when i bought my fuelab pump i asked the seller of the Walbro pump this very question,
My first one lasted for 40k... When it quit I figured ok, it just quit. Second one quit shortly after, about 10k or so, my pick up foot was plugged with crap so I figured...
This one is about 20k old, but has a 5/8" pickup to a 10mic water separator but its got a buddy, both outlets are being sucked on by a factory pump and a walbro.
Walbros deader then ####.
Just doesn't make sense anymore with the Boush pumps being $150 or so now.
Joe
CSIPSD is offline
post #10 of 10 (permalink) Old 05-30-2013, 04:22 PM Thread Starter
Does anyone have pictures of the setup for dual stockers?
