obs and sd push rods and valve springs? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 12-26-2008, 03:17 AM Thread Starter
got fuel?
goodstktbo's Avatar
do i have to do valve springs and
push rods at alittle over 400hp?or 500 even.
goodstktbo is offline
post #2 of 17 (permalink) Old 12-26-2008, 03:22 AM
strokin baby!!!!!!!!
broncof250444's Avatar
Re: obs and sd push rods and valve springs?
I dyno 479 Rwhp and two days later floated the valves and it kissed the piston result in breaking the rocker arm and bending the push rod.
2012 F350 CCSB Larait 4x4
MBRP 5", DPF and egr delete with H&S mini max!
500 rwhp/1200 ft tq
8.5 1/8 mile
13.3 1/4 mile
broncof250444 is offline
post #3 of 17 (permalink) Old 12-26-2008, 03:27 AM
What else?
smokyred's Avatar
I think I saw you have Swamps 250's and now a Sledge.....I would be putting them in if it was mine, it's not like they cost alot.
Also do you have headstuds yet? Since you're putting more charger on you should get studs too.
I've got about 1k in my studs/springs/pushrods, and to me it was well worth the money. Much cheaper than changing HG's or rockers/pushrods/pistons.
Dave
smokyred is offline
post #4 of 17 (permalink) Old 12-26-2008, 03:29 AM Thread Starter
got fuel?
goodstktbo's Avatar
Dave
yes i have arp headstuds in.thanks
post #5 of 17 (permalink) Old 12-26-2008, 03:40 AM
What else?
smokyred's Avatar
That's good to know, springs and pushrods are easier to install than studs, so this should be easier for you.
You ought to fill in your sig so we can see exactly what you have.
Dave
smokyred is offline
post #6 of 17 (permalink) Old 12-26-2008, 03:58 AM
sttstroke's Avatar
I have broke a rocker and bent a push rod with just a chip
Sold
sttstroke is offline
post #7 of 17 (permalink) Old 12-26-2008, 04:00 AM Thread Starter
got fuel?
goodstktbo's Avatar
what rpms??? and boost
post #8 of 17 (permalink) Old 12-26-2008, 04:03 AM
sttstroke's Avatar
4200 I dont know about boost I was in neutral with the parking brake on. I was thinking I wonder how far it will rev
Sold
post #9 of 17 (permalink) Old 12-26-2008, 04:13 AM
WTF were you thinking?
96 F350 4x4 35" BFG Mud T/A Weld SS II. Chip,Intake,4" Exhaust. Isspro Pyro,Trans,Boost. BTS. Hybrids,Fuel System,IDM,and Modded H2E from Bean. R&R Rods. Girdle and Push Rods from WOP.
phoneman is offline
post #10 of 17 (permalink) Old 12-26-2008, 04:19 AM
look what i can do
1badpsd's Avatar
i broke both rockers on the number 1 and bent 6pushrods on that side with just the mods in my sig but know i could have just put stock rods back in but with how i am it would only be a matter of time so i put comp 910's and david's pushrods in it know i just need studs and i tranny and i'll be ready for 500hp
1badpsd is offline
