what would be the best outlook monitor for me? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 12-25-2008, 05:19 PM Thread Starter
I keep hearing about pyro and egts and the other harmful things that can cause a diesel to sent to a early grave! I have done the basics to my truck already but before I start getting in too deep I want to be able to monitor all of my trucks stats can I get a little advice?
ironmule is offline
post #2 of 14 (permalink) Old 12-25-2008, 05:23 PM
Vozar's Avatar
Re: what would be the best outlook monitor for me?
what kind of truck do u have?
Year?
Motor?
Mods?
99.5 F-250 7.3 4x4
Vozar is offline
post #3 of 14 (permalink) Old 12-25-2008, 05:27 PM Thread Starter
I have a 2000 f250 std cab with 4" exhaust by banks kn filter and superchip which will soon be replaced with a custom chip by tony probably?
ironmule is offline
post #4 of 14 (permalink) Old 12-25-2008, 05:28 PM Thread Starter
7.3 of course
ironmule is offline
post #5 of 14 (permalink) Old 12-25-2008, 05:33 PM
Vozar's Avatar
Get a good set of guages....
Boost*
Trans *
EGT*
Ive have a set of autometer guages in my truck, i like pricol too.
99.5 F-250 7.3 4x4
Vozar is offline
post #6 of 14 (permalink) Old 12-25-2008, 05:36 PM
PSN Mega Miler
crowz's Avatar
I went with the diprocol gauges. Being on a budget so to speak Im doing them one at a time. Ive got the boost and pyro right now and will be adding the fuel pressure and trans temp next.
The pyro is probably the most important because if your exhaust temps are in the safe zone you can push the truck as hard as your want basically.
The boost gauge lets you know your turbo's health and if you have leaks anywhere.
Everyone has a particular gauge brand they are a fan of. I like the diprocol because they look factory and the needles dont bounce like some gauges do.
Also I prefer the pyro that uses the probe that you drill into the exhaust manifold since its not going to leak like the band clamp type can do.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #7 of 14 (permalink) Old 12-25-2008, 05:36 PM Thread Starter
what do you think of the bullydog out look monitor?
ironmule is offline
post #8 of 14 (permalink) Old 12-25-2008, 08:24 PM
PSN Mega Miler
crowz's Avatar
That would work, but I like the individual gauges myself for 2 reasons. They are showing you everything at one time and the second reason is if one gauge fails the others are still working. The bullydog goes out, your back to square one money wise.
crowz is offline
post #9 of 14 (permalink) Old 12-25-2008, 10:21 PM Thread Starter
that sounds good how difficult is it to install them I believe that the pillar one with the 3 gauge set up looks the best?
ironmule is offline
post #10 of 14 (permalink) Old 12-25-2008, 11:33 PM
PSN Mega Miler
crowz's Avatar
Mine is a 4 gauge pod above the rear view mirror. Im pretty short and the pillars are thick enough without adding something that makes it harder to see out
Heres how mine are done. I only have 2 of the holes filled so far.
http://crowz.narmir.com/F250/gauges.htm
crowz is offline
