New turbo = big problems, HELP!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 12-22-2008, 12:21 PM Thread Starter
A Ghost these days...
farm boy's Avatar
Ok, saturday i removed the turbo from my truck and installed a ported compressor shroud, turbine housing, and wastegate actuator. I already had the wicked wheel. I finished the install but now the trucks max boost is 12 PSI. It runs good but when I get on it, since it only puts out 12 psi, my exhaust temp goes through the roof cause there isnt enough air flow to clean up all the fuel.
Is there maybe an adjustment or can I correct this with tuning?
Sorry for the length. More info is better than not enough.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #2 of 33 (permalink) Old 12-22-2008, 12:25 PM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
Re: New turbo = big problems, HELP!!
Sounds to me like you need to adjust your wasgate acutator. I don't know what kind you got but you need to back it out so it will allow more boost to get to the egine? Good luck
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #3 of 33 (permalink) Old 12-22-2008, 12:27 PM
FNG
Dave's Avatar
Double check everything. Make sure nothing is leaking
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #4 of 33 (permalink) Old 12-22-2008, 12:30 PM Thread Starter
farm boy's Avatar
Nothing is leaking that I can tell. I have been all over the engine and can see nothing out of place. I unplugged the red hose that runs to the actuator to see if there would be a difference and no change.
farm boy is offline
post #5 of 33 (permalink) Old 12-22-2008, 01:05 PM
Snake Oil Salesman
mattr66's Avatar
make sure the wastegate is adjusted properly.... that rod is adjustable and may not be keeping the wastegate closed closed all the way.....
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #6 of 33 (permalink) Old 12-22-2008, 01:09 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
After you check for a leak a couple of times, check a few more times. Might try breaking out the soapy water.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #7 of 33 (permalink) Old 12-22-2008, 01:20 PM Thread Starter
farm boy's Avatar
I just hope I can do the adjusting for the wastegate while the turbo is still on the truck. I dont think I can go through the removal and reinstall again.
farm boy is offline
post #8 of 33 (permalink) Old 12-22-2008, 01:22 PM
Snake Oil Salesman
mattr66's Avatar
yeah just take the e-clip off the top of the wastgate and adjust the rod until it is holding the wastegate closed.
Matt Robinson
mattr66 is offline
post #9 of 33 (permalink) Old 12-22-2008, 01:25 PM
Proud PSN Sponsor
Deputydog's Avatar
Might check the up pipe connection into the back of the turbo. If that dowel didn't get seated into the turbo, it will leak like hell.
It sound to me like you have a leak somewhere.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #10 of 33 (permalink) Old 12-22-2008, 01:28 PM
Got Whistle?
crack_7.3's Avatar
sounds like a gnarly boost leak or thewastegate needs to be set. just crank that thing so its closed good and tight and unhook it and forget about it ha
08 F350 Lariat
Blacked
IDP tuned SCT
crack_7.3 is offline
