Just some input please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-13-2013, 03:23 AM Thread Starter
Diesel728's Avatar
Ok so the other day I decided to go fishing, well the spot I wanted to get to was on the other side of a not so big mud hole. I drove 90% of the way through the hole and at the exit where my truck started to angle out my rear end bottomed out. Locked in 4wd and the rear tires were off the ground, so I was turning the front tires back and forth trying to get traction and after a min or so I hooked up and drove right out. I say all that to say this. After getting back on the street I noticed that my steering wheel wouldn't center and that it was pulling pretty good to the right side, also when I turn to correct the pull to the right, the tucks seems to float and not wanna stay straight. I'm trying to figure out if its ball joints or just alignment, or what. Any advice or opinions. Thanks
2001 crew cab short bed Lariat, banks 6 gun tuner, 7" pro comp lift, 37"x12.5" Cooper discoverer STT, Mickey Thompson Side Biter wheels
SOOT LIFE
Diesel728 is offline
post #2 of 9 (permalink) Old 05-13-2013, 04:06 AM
Freak'n know it all
gottagofast's Avatar
Re: Just some input please
IMHO Why bother guessing
step 1: remove the mud
step 2: take it to the alignment shop
step 3: fix whatever they say has to be fixed before they can align it
step 4: take it back to the alignment shop
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #3 of 9 (permalink) Old 05-13-2013, 04:30 AM
geared_low550's Avatar
Send a message via AIM to geared_low550
One hub still locked in ?
08 250= sold
2005 CCSB 6.0= sold
2011 CCLB 350 dually lariat, 4x4, 6.7 all stock
95 ex cab long bed f250,4x4,7.3 auto with 4.10s and swamps tuning, 3 inch dp.for sale!!!
2002 ex cab long bed 4x4 7.3 auto. Stock and 294k on the clock.
geared_low550 is offline
post #4 of 9 (permalink) Old 05-13-2013, 05:21 AM Thread Starter
Diesel728's Avatar
I checked the hubs, I thought that's what it was at first. I'm just gonna do ball joints and have it aligned I think.
SOOT LIFE
post #5 of 9 (permalink) Old 05-13-2013, 07:05 PM
SledDogg's Avatar
Check the tire pressure in both tires first.
have the truck movie in about 15 miles per hour and then try to engage you transfer case very slowly. If the transfer case engagesvery into 4e wheel drive without making a grinding noise then one of your lock-outs is still engaged. I have had my stick and not disengage internally.
Az stated above by another poster wash all mine out of the wheel. You may have lost a wheel weight also which can cause this.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #6 of 9 (permalink) Old 05-14-2013, 01:24 AM Thread Starter
Diesel728's Avatar
Thanks sleddogg I'm gonna check all of that tomorrow
SOOT LIFE
post #7 of 9 (permalink) Old 05-14-2013, 06:33 PM
Village Idiot
southmike's Avatar
Jack up front-end. Put a long bar ..broomstick what ever under the tire...lever up and down look at the ball joints..is there play...have a helper turn wheels left right etc..is there play in tany of the links.
southmike is offline
post #8 of 9 (permalink) Old 05-14-2013, 07:30 PM
Village Idiot
southmike's Avatar
Jack up front-end. Put a long bar ..broomstick what ever under the tire...lever up and down look at the ball joints..is there play...have a helper turn wheels left right etc..is there play in any of the links.
post #9 of 9 (permalink) Old 05-15-2013, 01:18 AM
NWPAStroker's Avatar
If the center was high in the mud hole, you may have caught your cross tube. Check it to make sure it is still strait.
97 reg cab, zf5...srp1.1, irate fuel, valair clutch, hf/hv idm- totaled 4/12
04 yz450f- mostly stock-sold
09 wolverine 450 4x4-all stock
12 king quad 750. Winch, plates, executioners
L99 f250 Ecsb 6 speed, new addiction
NWPAStroker is offline
