h2e ex housings - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 12-21-2008, 10:13 PM Thread Starter
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
h2e ex housings
what is the next up from a 19cm? i may want to try one. i was runnin about 42psi boost and 54psi back pressure. i am puttin a 4" dp in instead of the three but if that dont help enough ill go bigger. thanks
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #2 of 16 (permalink) Old 12-21-2008, 11:25 PM
What else?
smokyred's Avatar
Re: h2e ex housings
If you're meaning bigger, that should be a 21cm. You don't have a mod h2e do you? If you don't, it may be time to send it in and get it upgraded.
Dave
smokyred is offline
post #3 of 16 (permalink) Old 12-21-2008, 11:59 PM
Sponsor
MidTennPSD's Avatar
Re: h2e ex housings
Yea thats what I was gonna say, I'd try it modded first. It could be a turd to spool w/ a 21. Oughta drop egts tho lol.
'02 F-250 CCSB Lariat 4x4 160's 38R
'97 F-250 5.9 CTD SCSB 4x4 XLT. [email protected] #2
'06 Jetta TDI Malone Stg 2 Tune
FullForceDiesel.com
615.962.8291
MidTennPSD is offline
post #4 of 16 (permalink) Old 12-23-2008, 01:50 AM Thread Starter
Crazy Talk
Re: h2e ex housings
it will be modded before it goes back on its off right now.
post #5 of 16 (permalink) Old 12-23-2008, 03:12 AM
Re: h2e ex housings
ive gota 23cm going back on mine with the twins. never ran anything other than a 17cm and a 19cm as a single though.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #6 of 16 (permalink) Old 12-23-2008, 03:18 AM
Pearson's Diesel
smokin dually's Avatar
Re: h2e ex housings
the 21cm is not fun at all to drive and very hard to keep lit while sled pulling. I went back to a 19cm and it is a better all around size
01 F350 cc dually 6sp conversion
00 F250 2.6 puller
early 99 F350 2wd daily driver
smokin dually is offline
post #7 of 16 (permalink) Old 12-23-2008, 04:03 AM
What else?
smokyred's Avatar
Re: h2e ex housings
How big are your injectors, and what mods to your H2e? We were going to try a 21cm on mine when I was going to go with an H2e.
Dave
smokyred is offline
post #8 of 16 (permalink) Old 12-23-2008, 04:06 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: h2e ex housings
newbie question, i know how the A/R is determined, but how is the "cm" determined in a turbine housing? I know a few companies that exclusively use the "cm" term
Stock
PowerstrokeJunkie is offline
post #9 of 16 (permalink) Old 12-23-2008, 04:13 AM
What else?
smokyred's Avatar
Re: h2e ex housings
IIRC, it's the R in A/R. It would be 21cm for the radius on a 21cm housing. Some manufactururs don't use both A and R, only R.
Dave
smokyred is offline
post #10 of 16 (permalink) Old 12-23-2008, 04:15 AM
Re: h2e ex housings
Area/Ratio
[url]http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech102.html[/url makes sense now, thanks.
Stock
