Adapters? Yes/No??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-10-2013, 03:47 AM Thread Starter
PSN Lover
shaneshorty's Avatar
Adapters? Yes/No???
My 35's rub really bad on my leaf's and I Don't want to get rid of my wheel's, I love them, I'm curious about like 1 1/2" adapters? Is this a really bad idea or will I be ok with them?
99 f250 7.3 Beans Diesel Custom Tuned, Edge CTS monitoring system, S&B Cold Air Intake, Double Oil Cooler, Double Filtration, etc.
I couldn't repair your brakes... So I made your horn louder...
shaneshorty is offline
post #2 of 10 (permalink) Old 05-10-2013, 04:23 AM
Super Hauler!
Super_Hauler's Avatar
Re: Adapters? Yes/No???
some say yes some say they have run them for years with no issues. I for one would never run them! I have seen them on jeeps and dodges before and have seen what they do when they decide to fail. Its not if but when with adapters or wheel spacers!
Super_Hauler is offline
post #3 of 10 (permalink) Old 05-10-2013, 07:26 AM
Dieselboy740's Avatar
I've ran them for years. If properly torqued you'll be fine. I've jumped my truck and it gets the crap beaten out of it and I've never had a issue. 2" front 3" rear
97 F-250hd d60 swap w/e-locker, shortened wheelbase, 37"s on double beadlocks, oba, 12k winch
1980 300sd Hy35, 3.5"exh, intercooled, Alda removed, pump turned up, 12" front brakes, lowered, bilstiens
2010 fe180 Mitsubishi fuso work truck, 3500lb crane, air comp, bobcat 250 welder, oil tanks
Dieselboy740 is offline
post #4 of 10 (permalink) Old 05-10-2013, 02:16 PM
Well made spacers properly installed and torqued are no different than dually adapters the factory installs. You will decrease the life of your front wheel bearings though due to the extra leverage on them.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #5 of 10 (permalink) Old 05-10-2013, 02:18 PM
7.3
7.3's Avatar
lift it up a little bit.
SOLD - 2001 7.3 zf6 sclb 4 inch exhaust, s&b intake, ts chip
SOLD - 2002 7.3 ecsb 4" exhaust, s&b intake, diesel site wicked wheel 2, diesel site 4r100 trans, 175/80 injectors, tuned by gear head
CURRENT - 2013 6.7 ccsb - Absolute performance intake, Absolute performance egr delete, Absolute performance tuning, 5" exhaust
7.3 is offline
post #6 of 10 (permalink) Old 05-10-2013, 06:10 PM Thread Starter
PSN Lover
its lifted 4"
post #7 of 10 (permalink) Old 05-10-2013, 07:55 PM
sooty
lifting wont change a back spacing issue
sooty is offline
post #8 of 10 (permalink) Old 05-12-2013, 06:34 AM
kbmkviii's Avatar
All I know is I have run 2" rear spacers hauling 12k plus with proper tq and locktite.
With the power in sig. Never any problems. Tq them and locktite them.
I rotate my tires frequently with no issues.
I only locktited the spacer bolts. The rest get tqed to spec with antiseize.
96- PIS 350 200s. 76mm Billett GT4202R. Big Oil. Twin E-Fuel.
BTS. Sump. 140v IDM. Melling. Fluidamper. H11. VS. PR.
Auto Meter- Boost, Pyro, HPOP, Trans, Fuel.
HPOP/coolant/trans filters.
6.0 I/C and Trans cooler.
2012 SRT8 300 6.4
kbmkviii is offline
post #9 of 10 (permalink) Old 05-12-2013, 04:34 PM
POWER Junkie
PSD POWER007's Avatar
Never any worries using these!
WheelAdapter.com Wheel Spacers
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #10 of 10 (permalink) Old 05-13-2013, 06:15 PM
We have them.
These are U.S. Alcoa 6061t6 billet aluminum, Lifetime warrentee, hub-centric and wheel-centric The spacers are roughly 3-5 times stronger than the Ford cast 20" wheels .
2" spacers will work without needing to cut off your existing wheel studs
We can get you 1.25-1.5" spacers but you will have to trim the studs shorter.
email:
Website:
OBSWIZ is offline
