intake - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 10-05-2007, 02:28 PM Thread Starter
Just A Squirrel
dstruble's Avatar
intake
I have a afe stage 1 and was wondering if it would be worth it to upgreade to the stage 2 or some other system??? Thanks for any input or ideas??
Darrin Struble
2003 F-350XLT Sport SC/SB
7.3L Live tuned by Jody ,ITP reg return/intank prepump mods, MBRP S.S. 4" ,afe stage1,foil delete,WW, Dieselsite coolant/trans filters,turbomaster wastegate controller,FTVB,Bandwagon Badges
1956 f100 Heidts Suspension all around
dstruble is offline
post #2 of 20 (permalink) Old 10-05-2007, 03:35 PM
Re: intake
make your own intake. way cheaper. and do the ccv mod. ill get some pics in a bit of my half ass intake.
PMRCM#1
slowleak is offline
post #3 of 20 (permalink) Old 10-05-2007, 11:47 PM
<- Sums it up
strokin_early_99's Avatar
Re: intake
I had a DIY intake for years and it worked great. The only thing that got me was when I put on my AE I found out that my intake air temp was over 200*. Then I decided to get a real intake and get the AFE stage 2 since I like to drag race and I sled pull.
So to make my long story from above short. Get the AFE stage 2.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #4 of 20 (permalink) Old 10-06-2007, 12:30 AM
Haul_n_horses2's Avatar
Re: intake
What was the intake air temp (manifold air temperature post intercooler or intake air temperature) after you changed to the AFE stage 2.
Haul_n_horses2 is offline
post #5 of 20 (permalink) Old 10-06-2007, 12:30 AM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: intake
Ilike mine, It's a bit loud at hwy speeeds, say 70 + . but I would never go back to anything else.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #6 of 20 (permalink) Old 10-06-2007, 01:20 AM
Re: intake
im sure i would like it too, but im just not rich enough lol. i do as many things diy as possible.
PMRCM#1
slowleak is offline
post #7 of 20 (permalink) Old 10-06-2007, 02:05 AM
<- Sums it up
Re: intake
In Redding, Ca, 105* ambient, my intake temps were running between 198* and 215* with an open air intake system.
In Sonora, Ca, 98* ambient, my intake temps were running between 110* and 120*.
AFE stage 2 with ZooDad mod was the only thing I changed between events.
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #8 of 20 (permalink) Old 10-06-2007, 04:22 AM
MAXIMUS OVERDRIVE
BDRUMMONDS's Avatar
Re: intake
Isn't the only difference between the stage 1 AFE and the stage 2 the cold air box and the torque tube? the Torque tube is avail from many vendors and the cold air box can be fabbed out of some nice 3/16 sheet, put some weather stripping on the top to seal against the hood and youre good to go.
ss
99.5 F250 4X4 CC SB isspros,DP, FASS pump, fuel bowl delete,SSHPX,OBA, 6.0 IC, 1.15 van turbo,ATS ported housing ,etc...
it goes and shows well for 320K
BDRUMMONDS is offline
post #9 of 20 (permalink) Old 10-06-2007, 11:16 AM
Re: intake
yeah im debating fabbing up a box to see if it helps. 80* temp difference seems like a good bit. strokin what type of temp sensor/setup do you have?
PMRCM#1
slowleak is offline
post #10 of 20 (permalink) Old 10-06-2007, 01:21 PM
<- Sums it up
Re: intake
the stock temp sensor. I use AutoEngineuity for data logging info.
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
