moving battery to pass. side - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-04-2007, 12:58 PM Thread Starter
coope3's Avatar
How many of you have moved your batteries to the passenger side. I talked to a ford tech. and he said I don't need the vacuum box since I don't have automatic hubs. This would ive some more room for the second battery. What do you think.
02 F350 CC 4x4, Common rail, 90hp injectors, Hellman intercooler,studs,twin cp3s,64/71/14 HTT turbo, HTT manifold,maxspool cam,Smarty POD,TS MP8,ported head, BTS tranny,PCS tranny controller,Airdog,Trac bars
2015 F250 CC 4x4 6.7 powerstroke stock
coope3 is offline
post #2 of 12 (permalink) Old 10-04-2007, 03:08 PM
Banned
Re: moving battery to pass. side
What are you doing that you cannot leave the driver's side battery?
And why not simply take the driver's side out......and stop right there?
Also, your HVAC functions are vacum controlled and your vent/defrost/floor and so on would not work without it. Or it might just keep cycling the pump on and off all the time instead of having the canister for a reservoir and kill the pump a little quicker.
I don't have two batteries FWIW.
Charles is offline
post #3 of 12 (permalink) Old 10-04-2007, 03:44 PM Thread Starter
coope3's Avatar
I am building a custom intake setup and could get bigger filters on if the battery was gone but I would like to keep two batteries. I use the truck batteries to power my quick connects to the winch on my gooseneck.
coope3 is offline
post #4 of 12 (permalink) Old 10-04-2007, 04:14 PM
OBS junkie
Cat_Rebel's Avatar
I'm thinking of moving my drivers side battery into the bed. I don't have enough room under the hood of my IDI to put two on the passenger side. All that you really need is a good amout of battery cable & something like a marine battery box & mount it in your bed or tool box. You can just ground it to the frame. I'm going to have to do that so I can fit a Tymar on my IDI.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 12 (permalink) Old 10-04-2007, 05:07 PM
Banned
Yeah, if you plan to use the battery power without the engine running then two batteries is mandatory if you still want to crank a powerstroke when you're done.
With the one I can't tell anything different except how long I can listen to the radio when working on a saturday or so before the wipers come across the windshield and the radio stops.....
Charles is offline
post #6 of 12 (permalink) Old 10-05-2007, 05:28 PM
Innovative Fabricator
stroker99's Avatar
Talk to Ryan Bean. He owns an '02 dually that has both batteries moved to the passenger side with the vacumn cannister still intact. I believe they are Optima Yellow-tops. Craig (Sapps) used to own the truck.
John
New Truck: '01 F-350, CC, LB, PSD, 4R100, gauges, intake, exhaust, chip SOLD
early '99 F-250, PSD 6-Speed SOLD
stroker99 is offline
post #7 of 12 (permalink) Old 10-05-2007, 11:25 PM
Starting Over
kainers's Avatar
I ran with one red top optima pass battery for 2 years the cold winter starts started to become a pain.
kainers is offline
post #8 of 12 (permalink) Old 10-07-2007, 07:33 PM
Moved in
sagebel's Avatar
I am running two yellow tops on the passenger side with the vacume canister relocated to under the truck just below the front passenger door. I think you could get away with not moving the canister but I like the extra room. I have my Viaair compressor mounted on the driver side where the battery was mounted.
Scott
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #9 of 12 (permalink) Old 10-08-2007, 01:16 PM
MAXIMUS OVERDRIVE
BDRUMMONDS's Avatar
Order up a frame rail mounted Big truck batt box and relocate both to the pax side frame rail. I dont have pics, but I saw one from another site.
that really frees up your room , and transfers some weight further back.
99.5 F250 4X4 CC SB isspros,DP, FASS pump, fuel bowl delete,SSHPX,OBA, 6.0 IC, 1.15 van turbo,ATS ported housing ,etc...
it goes and shows well for 320K
BDRUMMONDS is offline
post #10 of 12 (permalink) Old 10-08-2007, 02:27 PM
fbilly420's Avatar
I noticed the two batteries mounted on pass frame rail on the WOP truck in diesel power mag this month think they got the mount from JEGs if that is of any help.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
