VE and BSFC - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-02-2007, 07:19 AM Thread Starter
VE and BSFC
Working on learning to calculate turbo sizing.
For our engines, what are the best numbers for volumetric efficiency, and brake specific fuel consumption to use?
Thanks
gregrob is offline
post #2 of 16 (permalink) Old 10-02-2007, 07:21 AM
Starting Over
kainers's Avatar
Re: VE and BSFC
I use about 80% when I am calculating that is at 3200 rpms.
kainers is offline
post #3 of 16 (permalink) Old 10-02-2007, 07:21 AM Thread Starter
Re: VE and BSFC
Also, what are normal Intake Manifold Temps with a stock intercooler?
gregrob is offline
post #4 of 16 (permalink) Old 10-02-2007, 07:22 AM Thread Starter
Re: VE and BSFC
80% VE, that's pretty low we must drive outdated old pigs
What about BSFC
gregrob is offline
post #5 of 16 (permalink) Old 10-02-2007, 07:34 AM
Starting Over
kainers's Avatar
Re: VE and BSFC
2 gallons a hr at idle
kainers is offline
post #6 of 16 (permalink) Old 10-02-2007, 07:34 AM
HP Junky
Re: VE and BSFC
This turbo stuff is pretty interesting. Check out this link, it's pretty informative.
http://www.turbobygarrett.com/turbob...o_tech103.html
RockinJW is offline
post #7 of 16 (permalink) Old 10-02-2007, 07:35 AM
Starting Over
kainers's Avatar
Re: VE and BSFC
I know what you are doing and I have been there with those turbo calculators.Im gonna ust leave it the pro's
kainers is offline
post #8 of 16 (permalink) Old 10-02-2007, 07:39 AM
HP Junky
Re: VE and BSFC
I agree, it's still pretty neat trying to figure all this stuff out. Really helps you understand how a turbocharged system works.
RockinJW is offline
post #9 of 16 (permalink) Old 10-02-2007, 07:39 AM Thread Starter
Re: VE and BSFC
It is cool huh! Just the tip of the iceberg, wait til you get the book and it tells you how to do it for twins.
Not me
gregrob is offline
post #10 of 16 (permalink) Old 10-02-2007, 12:28 PM
Banned
Re: VE and BSFC
If you're talking about the HP books version that explains sizing compounds in the "Tractor Pulling" section, that is wrong.
I believe it is meant as a seat-of-the-pants ballpark method and not a valid calculation tool.
If that's the book you're reading you'd be best to put it down now while your mind is still fresh and pick up a good copy of Maximum Boost by Corky Bell.
I'm serious.
Oh, and I use 75% at 3000rpm, and 80% at 2800, 85% at 2500.
It's a 2v head with #### ports. Sure that's still pretty conservative, but I don't like surging turbos so I will always lean that way.
And what do you care about BSFC? This isn't a gasser, we aren't running Stoich.... (you cannot size a diesel turbo based on a presumed Air:Fuel) Diesels usually require a much bigger turbo for comparable power of a gasser. (Once again, rpm advantage of the gasser)
Good Luck.
Charles is offline
