TS switch location - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-17-2013, 01:40 AM Thread Starter
Randysrollincoal's Avatar
TS switch location
Just got my chip and tunes from Gearhead, i want to mount the switch in between the window controls and the lock/unlock button, any tricks on running the wire? or where have you mounted your switch?
Randysrollincoal is offline
post #2 of 9 (permalink) Old 04-17-2013, 03:50 AM
Coal Train Diesel
ventryjr's Avatar
Re: TS switch location
I don't think they come with enough cable to go thru the door jam atleast I no mine didn't. I must put mine on the dash panel about the fuse panel next to the steering wheel adjust bar.
Sent from my VS930 4G using AutoGuide.Com Free App
01 f350 dually CCLB, 7in lift, 6637 zoodad, 4.5" stacks, Isspro gauges, PHP Hyrda, ww2, industrial injectors 180/40
ventryjr is offline
post #3 of 9 (permalink) Old 04-17-2013, 03:56 AM
cheysays7.3!'s Avatar
I have seen it mounted above the window buttons on the door on an OBS. Can't remember what thread it was, just do a general search. Good luck!
1995 F250 ECLB - 6637, 3" MBRP downpipe, Autometer Pro Comp Ultra lite Boost pyro and trans gauges, Built trans, Proline FlatBed, and much more to come!
cheysays7.3! is offline
post #4 of 9 (permalink) Old 04-17-2013, 05:55 AM
FuturePharmD's Avatar
I mounted my switch next to the 4x4 selector on the dash. It's out of the way and in a replaceable panel if I ever have the need. Also there are some selectors available that are led indicators that mount in a gauge pod. They look nice.
2002 F250 ccsb Lariat 4x4
6637 intake
4" MBRP
Stage 1's by Full Force Diesel
Honey badger Jr hpop and Brute 66
Bellowed up-pipes and blank pedestal
No Limit Tuning by Jonathan (Dyno Proven)
Rough country level and shocks
305/70r16 Toyo AT2 on Dc2
Autometer factory match (pyro,boost,trans)
FuturePharmD is offline
post #5 of 9 (permalink) Old 04-17-2013, 03:10 PM Thread Starter
Did you put the case back over the PCM/tape the chip in?
post #6 of 9 (permalink) Old 04-17-2013, 11:11 PM
I cut the entire back out of the case, but yes a piece of tape is securing the chip.
6637 intake
4" MBRP
post #7 of 9 (permalink) Old 04-18-2013, 02:54 AM
biggin2001's Avatar
When I put mine in I left the case there and cut a hole in the case just big enough to fit the wire through so its still as factory as possible. I mounted my switch on the right side of the colomn so its not seen by anyone that walks up on the drivers side of my pickup.
biggin2001 is offline
post #8 of 9 (permalink) Old 04-18-2013, 12:57 PM Thread Starter
FInished the install last night
post #9 of 9 (permalink) Old 04-18-2013, 01:21 PM
Looks good !
02 CCLB DRW 6" pro comp , 35's , 4" down pipe, 5" back MBRP , K&N air , WW 2 , Edge juice
Robsdiesel is offline
