turbo upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 09-30-2007, 04:06 AM Thread Starter
sttstroke's Avatar
turbo upgrade
what is a good turbo for a late 99' that will just bolt on and how much $$$
Sold
sttstroke is offline
post #2 of 31 (permalink) Old 09-30-2007, 04:09 AM
HP Junky
Re: turbo upgrade
I'm loving my GT-38R from Diesel Innovations, I never used it on stock injectors, but it works awesome with my mini me's. I'm sure it would be just as good on the stockers though
RockinJW is offline
post #3 of 31 (permalink) Old 09-30-2007, 04:28 AM
Re: turbo upgrade
I like my 38r as well. Spools nice.
69W900A is offline
post #4 of 31 (permalink) Old 09-30-2007, 04:44 AM Thread Starter
sttstroke's Avatar
Re: turbo upgrade
How much do they run? Will it just bolt on?
Sold
post #5 of 31 (permalink) Old 09-30-2007, 04:51 AM
Re: turbo upgrade
Yes they just bolt on. How much depends on where you buy it. List price is around 1800, most vendors will sell for a bit under that. It's a very tough little turbo and will take a lot of abuse. Great small turbo for a compound setup as well.
69W900A is offline
post #6 of 31 (permalink) Old 09-30-2007, 06:46 AM
<----Colin Banks
mattymx's Avatar
Re: turbo upgrade
You can also get a TN turbo that bolts on. There is the standard .84 and 1.0 for about $1300 from BWD or you could get the TN BB 1.0 for about $1700 from BWD as well. I have ran both the standard .84 and now I have the new BB unit in the EX. It spools really well and there is no hint of surge at my elevation of 7000ft. The GTP38R has been known to surge for some people so that is why I did not get that turbo.
mattymx is offline
post #7 of 31 (permalink) Old 09-30-2007, 07:29 AM
Re: turbo upgrade
i love my garrett BB. No hint of surge, tho i still have stock injectors. but it works great, it never surged for me at 6000ft elevation
Diezel Dawg is offline
post #8 of 31 (permalink) Old 09-30-2007, 01:59 PM
<- Sums it up
strokin_early_99's Avatar
Re: turbo upgrade
TNBB Vs GTBB.....All right, another one..........
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #9 of 31 (permalink) Old 09-30-2007, 02:25 PM
HP Junky
Re: turbo upgrade
I ran the standard drop-in TN .84 with my stock injectors, and it worked great. Spool-up was awesome, I didn't see any egt drop with it, but the top-end pulled harder.
It was a different story when I put the mini me's in though. Granted, the TN turbo still had the .84 housing on it, so I can't make an even comparison. But when I took it off and installed the GT-38R, my egt's came down over 100 degrees while cruising, peak boost is up about 6psi, and the truck is much stronger. I dynoed 389 with the TN unit, mini me's, and stock fuel system. With the 38R and completed fuel system I dynoed 443.
I'm not bad mouthing the TN unit at all, because it worked better than advertised with stock injectors, it just wasn't enough for the Stage III's.
RockinJW is offline
post #10 of 31 (permalink) Old 09-30-2007, 04:08 PM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Re: turbo upgrade
Well a good turbo that will just bolt on would be an H2E, then you have room to grow with many different turbos to choose from. But it is a little more than the afformentioned turbos, however it comes with a ton more stuff.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
