t/c lockup when is it used - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-27-2007, 10:04 PM Thread Starter
Got 'Er Did
lownslow's Avatar
lower speed tc lockup is used for daily driving and higher speeds for towing?
tryin to play with my co-pilot
2009 Mustang GT Premium 5spd
BBK Long Tube Headlers and Off Road X Pipe
waiting for the squeeze
1995 F350 Crew Long 4x4 Dually
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #2 of 5 (permalink) Old 09-28-2007, 04:13 AM
Re: t/c lockup when is it used
I had Jody program my chip to lock it at 25 mph and it stays that way. When and at what speed depends on what you want it to do.
69W900A is offline
post #3 of 5 (permalink) Old 09-28-2007, 06:01 AM
utah get me two
the torque converter lock up switch mod,canbe done in about 15-30 minits depending on your talent........i use it alot
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #4 of 5 (permalink) Old 09-29-2007, 01:09 AM
Send a message via AIM to blackcloud2k
I use my TC lock up all day long. It is nice to have it stay locked when I am slowing down while towing since when I hit my brakes it unlocks unless I have it engaged.
blackcloud2k is offline
post #5 of 5 (permalink) Old 09-30-2007, 10:32 PM
X Racer
Racer X's Avatar
That's right, it can be used as a brake. Or as Engine to transmission 1 to 1 efficient power. Generally, gear 1 is too slow and will lug the engine at low speed. While it does the same thing as a manual clutch disc, it's a hydraulic coupling combined with a clutch. Much heaiver mass with the fluid weight, and behaves different than a dry clutch.
Co pilot is electronic and should unlock by itself. If your using a manual switch let speed and engine performance be your guide. Any low speed or load that lugs with the TCC applied is too slow. Enjoy it, the engine will always tell you.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
