Bowl Delete with Air Dog - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 11-03-2008, 04:09 AM Thread Starter
F-DuceFifty's Avatar
If I run an air dog set up, do I need another filter post pump if I also do a bowl delete regulated return fuel system?
1999.5 F-250 auto 4x4, edge ez programmer set at 60 h.p,Tymar intake. Soon to have 4" turbo back exhaust
I bet the Duke would have driven A Powerstroke
F-DuceFifty is offline
post #2 of 12 (permalink) Old 11-03-2008, 04:48 AM
Re: Bowl Delete with Air Dog
yes
SuperStroker10 is offline
post #3 of 12 (permalink) Old 11-07-2008, 01:50 AM
Village Idiot
southmike's Avatar
seems like I remember reading that sometimes a rr and fass/airdog don't always play well together without adding something .
iirc DI added a valve in the setup...might not be needed but I would ask dennis at itp or david at DI just to be sure.
southmike is offline
post #4 of 12 (permalink) Old 11-07-2008, 02:05 AM
add a walbro with the RR and airdog
post #5 of 12 (permalink) Old 11-07-2008, 04:56 PM
Construction Babysitter
wooner's Avatar
I haven't heard this before. Anyone have anything to add to this?
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
post #6 of 12 (permalink) Old 11-07-2008, 05:02 PM
Banning Smut
PTSUPERD's Avatar
I think he is talking about putting a ball valve in the return line on the fass. This comes in handy for dead heading it so you can set whatever pressure you want if you have the external regulator @ the motor. (to get an accurate psi.)
PTSUPERD is offline
post #7 of 12 (permalink) Old 11-07-2008, 05:57 PM
wooner's Avatar
I have the Airdog, and I believe it is pre-set from the factory at like 10 or 11 psi (I think). I am guessing this ball valve would not be necessary, or is already part of the system.
Dave
wooner is offline
post #8 of 12 (permalink) Old 11-07-2008, 06:08 PM
Member
vapstroke's Avatar
The ball valve is only for a high pressure fass not the airdog or low pressure fass.
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #9 of 12 (permalink) Old 11-07-2008, 08:31 PM
Oooo, White Lightning !
Dieselboy's Avatar
IIRC its a cheap little 2 micron filter.......Dennis knows what you need, its literally like 30 bucks, just splice it in to the fuel lines before the RR......
And I second adding the Walbro...
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #10 of 12 (permalink) Old 11-07-2008, 08:33 PM
Dieselboy's Avatar
This is what Dennis PM'd me when I asked........
Mike at Airflo sold it when he worked there, 10 bucks for the filter and 20ish for the head
What you need is a 2 micron filter setup between your fuel pump and the bowl delete block. I've been recommending a WIX 24770 filter base with a Baldwin BF7633 filter (or your favorite brands cross reference to that filter).
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
